Old 08-01-2012, 01:55 PM   #241 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Tango Charlie View Post
euromodder; if ya can't beat 'em, join 'em!
Won't happen with Hägar the Hitchless.
I'd need to get a hitch and get a technical check out due to fitting a hitch, which would cost a lot more than the boattail would save in fuel.
Even then, I can only make one that's disguised as a bike or wheelchair carrier, and then only 1m / 3,3' long.
Local regulations don't allow any other kind of extension, not even cargo racks.
Old 08-01-2012, 07:20 PM   #242 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Originally Posted by Weather Spotter View Post
So tc. When are going to build a tail?
I know you've seen his thread http://ecomodder.com/forum/showthrea...ail-22780.html .
I'm going to check out your rear window when I get there. I'm looking for brainstorming material.
Sorry to hear that euromodder. Stealthy mods only for you.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 08-05-2012, 06:50 PM   #243 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
JethroBodine:
No I had not seen his thread, I think he was trying to hide it from me
What ideas for a back window do you want? I like what I have but making one that opens, adds water sealing issues. mine is leak free right now, but its been an ongoing issue that I have fixed issue by issue over the last 18 months.
Well for an update:
I decided that my coroplast floor in the tail was not strong enough for much loading, and if I needed to access the spare tire area (jumper cables too) I have to crawl out into the tail. I also wanted to make it flat from car to tail. There was about 3/4 to 1" of drop to the tail. Depending on the grass at Tango's house I might have to use the car as my tent for our meet up in September, and the 1" of drop is annoying for that. So time to fix it:
Old out and new front to back support in place (2x4 ripped in half):
With front bracing in place:
I used some old book case 1x12 wood I had in the shop. it is stained so it will resist some moisture and look nicer then bare wood.
screwed in:
I also decided to replace the back piece of chloroplast as it gets dented when objects in the tail decide to slide back. it also was not holding up to sunlight well. the same wood as the floor will help and add some structural bracing to the back.
Now I can climb out to the end of the tail and not have anything break I do not think I want to put a load out there for long times but its strong enough to use it if I need to.
I am looking for cheep and nice looking options for the sides to hide the blue insulation. thoughts?
Now if I can figure out how to rig a curtain back there I will have a camper as well as a car
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
aerohead (08-06-2012), Piwoslaw (08-08-2012)
Old 08-06-2012, 09:23 PM   #244 (permalink)
Diesel
How about velcro on the inside of the supports and ready made curtains with velcro also on them? That's what I'm planning for mine. That and a velcro curtain dropping behind the front seats.
Maybe out door carpeting to cover the insulation? I bought some pretty big chunks for not much money( don't remember exactly) for flooring on my home made party boat. Cut to fit and staple in place.
Love the wood floor. Dude, if you can rip 2x4s in half, I'm not gonna mess with you.
Boat tail project
Old 08-06-2012, 09:31 PM   #245 (permalink)
Wiki Mod
Velcro is a great idea!
My mom suggested different curtains for each seasion.
Where did you buy the outdoor carpet?
About the wood, I like the floor too. On hot days it smells like wood, not fiberglass.
As for 2x4's
Have table saw, will cut, rirrrrrrrrrr
Old 08-06-2012, 09:55 PM   #246 (permalink)
Diesel
I bought the carpet at Home Depot. I think it was 6'x9' for $10 or something close. I got the grayish one, but I think there were other colors.
Meant to say that. Must have been thinking it really loudly.
Boat tail project
Old 08-07-2012, 09:00 AM   #247 (permalink)
Wiki Mod
I have been doing that loud thinking a lot of late. Its annoying. I will have to take a look.
Old 08-07-2012, 08:05 PM   #248 (permalink)
Wiki Mod
well my car to tail transition needs some work, its leaking again
I am trying to avoid the strong temptation to just fiberglass right to the car. I still want a vestige of being able to take it off.
just tossing some ideas out, share your please!
Vinal (car wrap the transition) how much gap can this cover?
smooth out the transition and use silicone to fill it in. Adhesion issues?
cut out 2-3 inches of fiberglass and spray foam the gap and reglass up to the car, leaving a small patch of foam exposed.
or toss hat in and fiberglass it right to the car.
Old 08-08-2012, 12:01 AM   #249 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Woof, I don't think I'd fiberglass it TO the car.
If you've got a decent coat of wax on the car, I think silicone caulk would be the ticket. It would seal it up, but be removable with a little elbow grease.
-Terry
Old 08-08-2012, 03:16 AM   #250 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I had the same sort of issues with my aero cap sealed to the cab. I'm guessing that since yer extension is moving/shifting, any seal you have attached to the car side will eventually break free. I tried securing lots of different things to the cab side with little success. I finally went with gap seal on the aero cap side. Keeping it tight to the cab was key to keeping water from leaking past the seal. I used some bungee cord to keep the tension on my gap cover...
http://ecomodder.com/forum/showthrea...tml#post314394
Dark Aero-The world's first aerodynamic single wheel boat tail!
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 05:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 10:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 11:30 PM
collapsible curved folding 10mm coroplast boat tail miket Aerodynamics 5 08-12-2010 02:58 PM
Subaru Outback Prototype Boat Tail Test Results brucey Aerodynamics 10 10-02-2009 06:03 PM
