Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 08-08-2011, 09:56 AM   #11 (permalink)
BarelyAWake's Avatar
True, true - chains can be both messy & noisy, yet the (marginal) friction losses of a belt drive yet w/all the same or worse tensioning issues resulting in slip (suspension travel too), I figure for this app, chains were the way to go...
Belts are a nice option for a standard bicycle four stroke conversion tho, I'm sure you're familiar with Wizzers?
I wish ya had a coupla pics of your ol' "trike go-cart" lol, such beasts are always awesome to behold
Old 08-08-2011, 09:24 PM   #12 (permalink)
Wow, that is some beautiful work. Amazing little machine!
Old 08-15-2011, 01:56 AM   #13 (permalink)
Thanks Chromedome, sorry for the delayed reply...
TBH, I do think tadpoles are a lil... odd looking save for the form following function aspect ofc *shrug* I've dabbled a bit with trying for a "pretty" motorized bike* & while I do like it, it's got about a 100 mile range maximum - or to be more accurate, I've got about a hundred miles I can put up with before I'm totally sore & exhausted, despite the sprung forks & seat and it's balloon tires.
While I've done my best to quiet it, the noise & vibration of the cheap two stroke has a lot to do w/it as well...
Which is ofc what lead me to look into a four stroke/electric suspended tadpole
*a (mostly) 1943 Rollfast;
photo album: Rollfast pictures - Photobucket
Old 08-15-2011, 12:27 PM   #14 (permalink)
Any thoughts of building a streamlined shell a la the Quest velomobile?
Old 08-16-2011, 06:30 AM   #15 (permalink)
Yes actually, lots of 'em - so many in fact it's given me a headache lol
TBH, turning this thing into a full fledged velomobile is more than a lil bit of a challenge and I'm not sure about the consequences... everything is a compromise & one of the ones I had to make was it's overall length in order to motorize & suspend. I've been trying to keep it's wheelbase as close as possible to other "preformance" tadpole trikes - but I did hafta add roughly 10" to it's wheelbase to squeeze the motor in there w/the rear suspension's travel accounted for... and it all adds up.
Here's it's measurements BTW;
wheelbase (contact patches) 4'6"L x 32"W
8' LOA x 3'W x 3'T (top of helmet rest)
While that may not seem like much & it isn't particularly in height (gonna defo need the silly orange flag lol) - as soon as I start trying to match a body shell to it, it starts getting ridiculous, the width and very much the length start becoming relatively unmanageable, a minimum of ten feet long for example (pedal/feet clearance).
Add in some factors like difficulty in entering/exiting, visibility concerns (mine, others would ofc see me even better), weight & balance (leaning body mass for stability), ground clearance (suspension travel), and transportability (it just fits in the back of a pickup ATM) as well as the admittedly minor, even trite considerations regarding aesthetics... and it's become overwhelming to the point that I've shelved the idea for now...
...but I am w/o doubt open to any & all ideas regarding any aerodynamic suggestions or body shell ideas, I've not given up on it by any means - I've jus' got a couple few far more basic things on my plate lol, in the interim I've been considering one of these: Mueller Human Power Recumbent Fairings and Bicycle Windscreens
As for those "basics", I did finally get my pedal chain & power idlers sorted - other'n some lil things, the chassis "fabrication" stage is done & now it's all modification and component work
Old 08-16-2011, 11:50 PM   #16 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
Add in some factors like difficulty in entering/exiting, visibility concerns...
Mine was 9' long with the full fairing since I have a hub motor, and no frame extension, 40" wide, and 3' high with the roof on from 2005 t0 2010, then I took the top off then removed the shell in 2011. Amusing that you are thinking ahead (like I should have). I had to get in like a "pretzel" into a 4" off the ground floorboard into a 2' long open door. Couldn't see behind me with the top on (whale tail was also a headrest).
What "ruined" it was speed. I went my top speed downhill; then aerodynamics and gravity took over. Climbed right out of safe control. Way too fast! When I stopped - I dismantled the trike the next day. Scared me!
The rebuilt trike top speed is nowhere near what it was; but that is fine with me! I do not care for those orange flags, but that 2 tone 'Be Seen' flag is good enough!
Old 08-18-2011, 04:35 AM   #17 (permalink)
Thanks for sharing your experience Christopher, I'm basing my decisions mostly on "gut feelings" and quite a bit of clicky research lol - I've no time on a recumbent/taddy whatsoever, this 'uns my first
So your feedback is greatly appreciated - while I'm not building it for speed, I am trying for efficiency & it's interesting to note the two are often intertwined... I suspect this thing will be plenty fast 'nuff even w/o a body, but still, I'd love to see what kinda mileage I'd get w/one.
The 'Windwrap' fairing I linked to prolly isn't the best for aerodynamics despite it's advertising, I'm most likely still going to try one for comfort considerations though...
Old 08-19-2011, 01:47 PM   #18 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
The mueller fairing makes a pretty fair front if you attach coroplast sides. By itself you probably won't notice any difference.
Your drive train makes a lot of turns. how much friction do you notice when you pedal backwards. I think it is a reasonable measure of drive line friction. Hope that you are using quality idler wheels.
Mcmaster carr sells nice v belt pulleys with ball bearings that make great chain idlers.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
HHOTDI (09-28-2012)
Old 08-20-2011, 04:21 AM   #19 (permalink)
I agree, w/o the sides & tail I suspect a fairing would be mostly for comfort - which ofc I've no aversion to lol... yet seeing the above pic has brought another concern to my attention & one I'd not considered before (thanks BTW), & that's weather - most particularly side gusts.
While the above body shell no doubt vastly reduces wind resistance under ideal conditions & it's hard to tell from the pic how tall it actually is - I can't help but wonder what effect it had on handling & control, say w/a variable 20mph crosswind for example... a phenomenon not uncommon at all on the coast of Maine (to be guilty of a grave understatement heh). While I think I'd have some advantage over the above (what appears to be) bicycle with the lateral stability a trike provides... I think perhaps I'd attempt a more "form fitting" body, reducing it's profile as much as possible.... which granted, my not be possible at all.
Unfortunately yes, my pedal chain takes a somewhat convoluted route & worse yet it's redirects are on the power side. After many admittedly silly attempts to pass it through the A arm suspension (to try and increase ground clearance), I resorted to blatantly copying the chain path used on an unsuspended taddy. As I've that great honkin' engine case in the way - I've little choice. It's only a lil 49cc four stroke, but as it's an auto clutch (I've already too many levers and whatnot lol) it's somewhat wide (11").
I do appreciate the link to the V belt pulleys as it seems the second ya seek "recumbent" bits, the price triples regardless of how basic the part may be - strikingly similar to "marine" or "aviation" stuff it seems lol, I took another option however and one that's seemed to work really well. Despite the fact my "clicky" research informed me that I should use cogs on the power side (to reduce the felt vibration of links passing over a roller), I simply got some inexpensive skateboard wheels and lathed them down to accept the chain & replaced their shoddy bearings w/some quality sealed ones I happened to already have. I'm planning on getting some better skateboard wheels at some point, a softer compound (again, reduce felt vibration) yet at the time the cheapos were all I could find locally & as I'd never attempted to lathe skateboard wheels before - I figured these would be good enough for my experimentation.
As it turns out it worked really well, with the teflon chain return tube, 'Starboard' (fancy overpriced plastic, same as a cutting board tho) chain retainers & tube supports and the new route - I can now pedal and back pedal freely w/o binding or undue friction... ofc there's some friction, but the pedals will free spin a couple of turns despite the chain being bone dry.
I'm thinking there will be far more drag from the jackshaft & engine chain (clutched) than there is from my two pedal chain idlers... yet this "pedal assist" motorized trike differs a bit from others in that I hope to pedal to assist it as opposed to it assisting me, should somehow two out of it's three motive systems fail leaving only my leg power... well, I hope I'm not too far from home lol - it's heavy for a tadpole trike if nothing else. It still weighs in less than a factory new two stroke Tomos moped however, something I'm perhaps disproportionately proud of - and I can thank it's LifPo4 battery packs & (double walled) aluminum wheelset for
Here's a coupla pics of the idlers while I was making them, I may redo them as I can squeeze a hair more ground clearance if I remake the Starboard & stainless bits... but it'd be fractional at best *shrug*
Old 08-20-2011, 10:05 AM   #20 (permalink)
Do more with less
Here is an early web page showing the bike and the coroplast fairing. coroplast fairing
I have ridden it fully faired on a lot of centuries, road races and track events. It does fine in the wind when running in the mid 20 mph range. The key to having a good handling road machine is to keep the the nose spherical and the body short.
a mueller fairing would be the start of nice streamlined shape. Mueller will sell overblown fairings pretty cheap. Just build a mount and you are in business.
When your skate wheels fail consider the pulleys. Don't worry about having the teeth.
Noah Webster, 1787
