Old 08-16-2013, 02:38 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Ran it back in the 80's & 90's in a 66 mustang, 79 RX7, 86 Pontiac 6000 STE, Several audis.
Never had any problems.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
sully06 (08-16-2013)
Old 08-16-2013, 09:53 PM   #12 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Zmax
https://www.google.com/url?sa=t&sour...brpPKhprnbWBiA
Slick 50
https://www.google.com/url?sa=t&sour...a9LI9_2qwZBHYw
Old 08-16-2013, 11:11 PM   #13 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
came across this the other day, seems relevant to this thread.
F1 lubrication - Forum - F1technical.net
lubromoly/petromoly
i've never heard of it and i've seen a LOT of oil additives before, almost all of which were based on junk "science". it appears that this may or may not have a basis of fact.
Old 08-17-2013, 11:47 PM   #14 (permalink)
mcrews's Avatar
As a note, I was into mpg(a little bit) just didn't a-b-a test things back then. My " recollection" is that I got better mileage.
ECO MODS PERFORMED:
First: ScangaugeII
sully06 (08-18-2013)
Old 08-17-2013, 11:57 PM   #15 (permalink)
i guess i'll share:
i've used slick50..... once..... pretty sure it did nothing but thin out my wallet.
anyways, did more research on the lubromoly/petromoly, turns out some of the BITOG guys have also played with it, reports of 3% gains seem to be the norm, even when used in oils that already have decent amounts of moly in them.
looks to cost about $9/quart at most stores. most seem to use a "full" dose once, then half doses afterwards to keep the level of moly in the oil after a change high enough to have an effect.
at a 3% gain at 30MPG, that's 30.9MPG. assuming a 5,000 mile oil change interval, you'll burn through 161.81 gallons of gas instead of 166.67 gallons, a difference of 4.86 gallons. assuming $3.50/gallon, that's $17.01 of fuel saved by spending $9 on an oil additive. that's for the initial dose. "maintenance" doses, $17.01 by spending $4.50.
and if you run oil changes longer than that, you'll save more.
so, pretty small number, but interesting to see something having a benefit.
Old 08-18-2013, 02:30 AM   #16 (permalink)
looking to get 100mpg
lsemple's Avatar
Si Civic - '93 Honda Civic Si
90 day: 41.16 mpg (US)
try Z-Maxx instead !!
The Following User Says Thank You to lsemple For This Useful Post:
Old 08-18-2013, 09:35 AM   #17 (permalink)
As the msds link I posted shows, zmax and slick50 are entirely/almost entirely mineral oil. If it does work you could save yourself some money.
The Following User Says Thank You to ksa8907 For This Useful Post:
Old 08-18-2013, 11:01 AM   #18 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Not since the 80s.
I tried it for a couple of changes in an older car and didn't note any of the so-called "improvements." Fuel mileage stayed the same, engine sounded the same, no perceptible change in power output. My assessment then was about what it is now: snake oil.
Hmm. I wonder if you could render oil from snakes. Would it do better?
Old 08-18-2013, 01:28 PM   #19 (permalink)
Ecomodest
Jasen's Avatar
The Van - '97 Chevy Astro AWD cargo van
90 day: 14.03 mpg (US)
I've never read any real world praise about it or the like.
I do run Lucas oil stabilizer in my high mile rig's. The motors run smoother and quieter, with quieter cold start's. As far as helping EF, I can't say other then a smoother running engine is going to be more efficient.
Being a mad scientist is not as easy as it looks on TV
The Following User Says Thank You to Jasen For This Useful Post:
Old 08-19-2013, 09:01 AM   #20 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
lubromoly/petromoly
Moly seems to be legitimate. It's not pushed by one specific company as an additive. There are oils that use high amounts of moly for it's benefits.
The Following User Says Thank You to Miller88 For This Useful Post:
sully06 (08-19-2013)
