Old 03-06-2008, 10:52 AM   #31 (permalink)
90 day: 51.82 mpg (US)
No kidding! Did you offer to pay for the electricity use? Or was that not the issue...
Old 03-06-2008, 11:11 AM   #32 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
You need a transmission pre-heater too. (In fact we all could use one.)
Don't forget wheel bearing pre-heaters.
Old 03-06-2008, 11:37 AM   #33 (permalink)
Who
UnderModded
I'd like an outdoor temperature controlled timer with a straight line mapping.
5hrs @ -25° C
4hrs @ -15° C
3hrs @ -5° C
2hrs @ 5° C
1hr @ 15° C
I've used 3½ hours most of the winter. It's a 400 watt heater in a 3.3L V6. It seems to top out at around 30°C (86F) if you leave it on long enough. I'll back it down to 2 hours at the end of this month and then down to an hour at the start of May.
Old 03-06-2008, 11:41 AM   #34 (permalink)
Who - so you're saying yours "tops out" after 5 hours?
Old 03-06-2008, 12:17 PM   #35 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Electricity use wasn't the issue (cost less than 4¢ per day for work's electricity). It was because my car was parked near the maintenance garage, and on of the other staff thought that I was getting a special parking space closer to the building. In reality, the spot I was parked in was only 5 ft. closer to the main building than the closest parking spot.
I made sure to inform all the staff that asked me, why I was parking there and most of them understood. Although, nearly all of them asked why I was still plugging in my car when the temps were just getting above 30°F, hehe. I then had to explain that 30°F is still a long ways away from 180+°F (the temp at which the thermostat opens on most cars).
Meh, I chalk it up to ignorance and jealousy of coworkers. It's all good though because I'm the IT Guy at work, so they all respect me anyways....and think I'm a little weird.
Old 03-06-2008, 12:30 PM   #36 (permalink)
Who
UnderModded
It would take far less than 5 hours on a typical night to effectively saturate the ScanGauge reading (it is possible that the rest of the heat is still conducting to areas that help - exhaust manifolds for instance).
Those times above would be my guess on how long it takes to get to about 29° C (engine target temp is 80° C). My commute is very short and in the winter that means very high consumption rates so I've tried to max the block preheat, without using more money for electricity than the gasoline it saves. I save a nickel a night, so assuming 200 nights a year plugged in, it's only a 40 year payback.
The auto mfr.s of cars for cool climates could really help out. I'd like to see some insulation on both the block and the tranny. Let the cooling systems do the cooling, let the casings hold the heat. It wouldn't take much and could also reduce noise slightly.
I'd also like something like smart shore power. You park and plug and as you leave you set a time (maybe 7am). The car's sensor checks battery charge, engine temps, interior temps and outdoor temps. It then times everything and based on the input temperatures prepares the car so that at 7am, the battery is fully charged, the interior/seats/glass aren't freezing, and the block and tranny are pre-heated optimally. Much better than the remote starter option!
Old 03-06-2008, 02:55 PM   #37 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
That would be great!
I'm not the best with electronics, so bear with me...
How about a temperature-based timer/cycle circuit on the EBH? Take temps off of the block and have the circuit cut the power at X-degrees, and if you're not back in time, re-engage the heater like a home furnace.
Or even, would cycling the heating process produce more even-heating with less energy over a long period of time?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 03-06-2008, 02:57 PM   #38 (permalink)
I"m not lurking!
s2man's Avatar
Porthos - '96 Chevrolet Cavalier
90 day: 31.3 mpg (US)
Or, they all fear you, 'cause you could cause their files to dissappear, or the servers to slow down.
Stew
"I don't do windows"
Roll on,
Stew
Old 05-08-2008, 07:24 AM   #39 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I read an interesting paper on block heaters yesterday.
REDUCED COLD START EMISSIONS THROUGH USE OF ELECTRIC ENGINE HEATERS
Did you know that using a block heater year round can help reduce your carbon footprint by over 500 pounds?
Did you know that by using a block heater you can reduce your overall CO and HC emissions by up to 80% on a 3.5 miles trip.
Did you know that using a block heater saves your roughly 0.07 gallon per cold start?
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-08-2008, 09:06 AM   #40 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by DifferentPointofView View Post
Would a magnetic one work for that? (would it also work for a freeze plug type?)
I bet it would on your steel paned automatic trans.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Engine efficiency improvement through higher temp thermostat? Lazarus General Efficiency Discussion 23 09-16-2015 02:27 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
How much fuel does it take to re-start a warm engine? MetroMPG Hypermiling / EcoDriver's Ed 9 08-15-2009 02:31 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
OBD-II / Factory Specific Engine Scanners DrEMHmrk2 Instrumentation 4 01-04-2008 12:49 PM
