Old 08-27-2008, 09:20 PM   #1 (permalink)
Ruby - '07 Toyota Tacoma Base
90 day: 32.44 mpg (US)
I Could Use All the Help I Can Get
Hey Everybody,
I feel like I'm finally home. I've found a bunch of neat folks into saving gas, and getting the most out of their vehicles. My friends think that I am nuts, with the records I keep, and the way I preach about saving fuel, and ecodriving. For those of you that might remember the time, I began driving around the time of the first oil embargo, and have been driving accordingly ever since. Man...I am no spring chicken.
I have a 2007 Toyota Tacoma, with which I am already beating the odds. My mods to date are: synthetic oil, tonneau cover, tires to 39 psi, partial grill block(top portion), and ScanGaugeII. I have a set of smoothie hub caps due Friday 8/29. I have been researching lowering kits, one which takes 3" off the front, and 4" off the back...someday! My overarching goal is 40 mpg.
My question, for right now is: If I do a partial grill block, what is the best way to vent the air that I let in? I have looked on the underside of the hood(bonnet), and it seems that there is a structure there that seems as though it were meant for a form of ventillation. I am thinking that this might be a good place for a rearward facing scoop. The resulting vent holes would be just aft the radiator. Are there any rules for hole size, other than Area in =Area out? Tricks?
Are there better gains to be had?
I have 13 Airtabs. What would be the ideal placement on a Tacoma? I have my doubts on a vehicle of the size and shape. It seems they might work well on a box truck, or semi-trailer. I tried them at the rear end of the cab with no effect. I now know why. My next try is just above the tailgate. Does anybody have any real world results,data?
Is there anybody out there from Greenville/Greer SC?
I look forward to hearing from y'all.
Best Regards,
TacoDog (Doug)
Old 08-28-2008, 12:13 AM   #2 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Hey Doug-
Welcome to EM...
Check out the 104+ Mods section and try a few things out. Plus, there are lots of Taco drivers here that can lend a hand.
Best FE to ya...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 08-28-2008, 09:10 AM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Hi Doug -
You're doing very nicely with the Tacoma so far. As for "venting" air that enters for cooling, is it not already venting beneath the truck?
Airtabs: I've done a very limited amount of testing which has NOT removed my skepticism that these reduce fuel consumption. See: http://ecomodder.com/forum/showthrea...olla-2390.html
If you do a fair amount of highway driving, I'd be looking at constructing an aero shell bed cap - far greater gains to be had from that than anything else at higher speeds.
Welcome to the site!
Darin
Old 08-28-2008, 09:28 AM   #4 (permalink)
Here's my plan for my Dakota, if time ever allows. Upper grille block, air dam/ spoiler directly under radiator, smooth underbelly housing a duct to move underhood air to the rear into the drag zone behind the truck. This should (at least I hope it does) clean up a lot of the turbulence.
Old 08-28-2008, 10:49 PM   #5 (permalink)
39 psig? Too low, be brave!
Hi, Taco !
39 psig? Hmmm.... keep going. Some people stop at 40psig, some go over ( I use 44 pgig, and the ride is plenty firm), some go way over! I'm not afraid of 50 psig...but old habits ( and good results) are hard to break. Be brave...they won't pop! But they'll roll much easier at any speed ( less HP).
Old 08-29-2008, 03:14 AM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
TacoDog -
Welcome to EM! Lots of good MPG Tacos here. I had MPG spreadsheets starting around 2002, but now Ecomodder does that for me!!!!!!
What does MPG mean for a Taco? Menudos Per Guacamole?
CarloSW2
American Solar Energy Society
