Old 04-29-2008, 11:08 PM   #21 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
Sorry, I meant a 155/85/13.
Even if they don't work, I'd still be interested. I'm just brainstorming a non-roadgoing vehicle at the moment and those tires look perfect.
- LostCause
Old 04-30-2008, 02:28 PM   #22 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
If I may interject, VW beetles use to run a 145/15, which was the skinniest tire I ever new until we began lowering beetles and running doughnuts as tires, which I think were 125/15's.
www.whitewallcandystore.com search under beetle and you wil see them there. $160 each I think
Good Luck
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 04-30-2008, 04:59 PM   #23 (permalink)
cbergeron's Avatar
aerospire - '95 Ford Aspire
90 day: 56.92 mpg (US)
Hindsight - '00 Honda Insight
Those tires are 115/70D14's.
They're very tiny.
Old 05-07-2008, 11:43 PM   #24 (permalink)
cbergeron's Avatar
I've added moon hubcaps, swapped my rear wheels with thinner profile "donuts" and I saw a significant boost in MPGs.
Here's a more recent picture of my car/mods:
Old 05-07-2008, 11:48 PM   #25 (permalink)
cbergeron's Avatar
It should be noted that by having small/thin tires on the back of the car, the steering is very "boatish". By boatish I mean she has a boat-tail effect to her, so at high speeds she's very unstable. It's like pushing a shopping cart in reverse.
I can't drive her beyond 55 mph in this configuration. Since she's my commuter car and I work close to home I don't ever need to drive her any faster, so it works out quite well.
Old 05-08-2008, 11:19 AM   #26 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Yikes! I'd imagine you could have alot of oversteer with those back tires! I have 155/85R13 snowtires for my neon and even those result in boatish handling although balanced with 4 on. If you are going to run significantly skinnier tires on the back you should do a couple of parking lot tests for steady state cornering and then some hard braking while turning hard, just to see if you have understeer or (hopefully not) wild snap oversteer. I'd bet with skinny 13's your car now has balanced handling and not hopeless understeer like most cars but you should check.
I'd imagine an Aspire could be rolled if its suddenly sideways at 55mph. Mpg tends to drop when sliding on the roof....
Not trying to scare you but you should atleast practice abit with an extreme tire setup so its not a surprise in your first accident avoidence maneuver.
Play safe!
Ian
Old 05-08-2008, 08:25 PM   #27 (permalink)
Boy Racer!
The Mouse - '08 Mazda 3 S-Touring
90 day: 29.12 mpg (US)
Send a message via AIM to Tripleskate
Woah, those rears are so tiny! It seems like they would effect the overall ride comfort of your car? Any truth to my theory?
2008 Mazda3 Hatchback Mods
-VG Sharkfin -BuddyClub Volt. Stabilizer
Old 05-08-2008, 11:50 PM   #28 (permalink)
90 day: 51.82 mpg (US)
IndyIan offers good advice, I'd say. Safety first, etc. etc!
To clarify the mpg boost you saw, are you saying you saw the gain when you went from wider tires all around to 2 narrow fronts plus the rear donuts? Or you saw the gain after going from 4 regular narrows to 2 narrows and the donuts?
Old 05-09-2008, 09:00 PM   #29 (permalink)
cbergeron's Avatar
I drive very consciously and safely with these wheels during this experiment. The rear of the car definitely 'boat tails' at high speed, so I can't go above 55 with this configuration. I never go that fast during my commute, so it's not really an issue (unless I'm coasting down a big hill and trying to get up as much speed as possible for coast).
Well, after thinking about it more, by adding these skinny wheels netted out less of an increase than I previously thought. For one thing, these wheels aren't broken in yet. More importantly, by replacing the wider wheels with narrower ones I've created a gap in the rear wheel well that acts like a parachute.
During this most recent tank, I did a wiper delete, passenger mirror delete and replaced a major trim piece on the passenger door. I have a feeling that those mods netted my higher MPGs and the skinny wheels netted out even.
I think I'll see a significant increase when I install rear wheel covers.
Tripleskate: Suprisingly, aside from more sensitive steering, the ride isn't much different. It rolls nicely and they make a neat whine sound that sounds like an electric motor. It's very subtle, and I actually like it - considering that one day I'd like to convert this bird to an electric.
Last edited by cbergeron; 05-09-2008 at 09:03 PM.. Reason: Replied to Tripleskates question
Old 05-09-2008, 09:08 PM   #30 (permalink)
cbergeron's Avatar
I'm hypermiling for fun, but it's tricky because there are so many X factors: other drivers, traffic lights, school busses (got stuck behind one today, ugh), etc.
It would be neat to see the effect of my changes in a lab environment, but I'm having fun with it as it is. I just bought a Honda Insight, so it should be fun playing with that once it gets here.
Car and Driver magazine ecomods a Pinto: MPG up +25% MetroMPG EcoModding Central 34 01-29-2014 07:00 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
Article: Smart car scores hat trick in Canada - now cheapest new car available MetroMPG General Efficiency Discussion 17 02-02-2008 03:41 PM
Article: Smart car offers fun along with fuel efficiency MetroMPG General Efficiency Discussion 0 01-29-2008 08:39 AM
