Old 09-08-2009, 05:13 PM   #1 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
Question high idle cold
I am winding down another summer, and need high idle again. I forget where it is supposed to be. in the dead of winter, it climbs to 2500, but that same setting in the summer goes to over 3000. no inbetweens apparently.
what is you warm time cold start idle?
Old 09-08-2009, 05:15 PM   #2 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
when my car is cold it idles around 15-17 inches nt
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-08-2009, 10:46 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Around 2-grand on a super-cold start.
There may be something amiss with a control valve of sorts (idle-air, etc.) On mine, it's a wax-based internal that melts at "warm" and allows proper intake flow. If it's solid, the air is bypassed, allowing a higher idle.
EDIT: Since you have a carb, make the appropriate adjustments with the set-screws.
Just jam it into 2nd and roll with it right away -- idling is your enemy. I do that with the automatic and let the extra idle carry the car. If you don't have some sort of engine block heater, I would get one now.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
Consumption at idle groar Instrumentation 12 01-17-2009 07:12 AM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 12:41 PM
