07-26-2018, 06:13 AM
#81 (permalink)
Yeah, dead certain. I also lost lean burn whenever I ran my hybrid battery too low, it wouldn't come back until I had enough charge to assist/regen or auto-stop.
07-26-2018, 01:17 PM
#82 (permalink)
Hey - I think we can move this thread from "off topic" into EcoModding Central...
The fact you're planning a gear swap to retain good highway mileage qualifies as ecomodding, I'd say.
07-26-2018, 01:20 PM
#83 (permalink)
I've also decided to go with a modded ECU, and will likely play with a lean burn tune.
![Turtle](/forum/images/smilies/turtle.gif)
07-26-2018, 03:26 PM
#84 (permalink)
TSX lightweight magnesium alloy transmission was ordered a few days back. Accord cable throttle body, RSX ECU and harness, 02 Civic Si knuckles, ball joint adapters, harness adapter and clutch ordered. Soon to order a wideband O2 sensor for it so I can tune lean.
EDIT: Going to cut up my fuel filler lines and re-route them, ordered a set of hoses to replace them with.
07-26-2018, 04:54 PM
#85 (permalink)
Hah, and I'm intimidated to check the valve clearances on my motorcycle. When things inevitably don't come apart or go back together as easily as I expect them to, I completely lose it.
I spent 3 hours removing 2 bolts on the motorcycle last week, and 2 hours putting them back in. My CCT lifter better never rattle again, or I'll put the bike in a crusher.
07-26-2018, 06:53 PM
#86 (permalink)
You do not have the option to put a 1.2 lliter tdi engine in there do you?
That would make a truly awesome car.
07-26-2018, 11:37 PM
#87 (permalink)
I believe someone came here several years ago and posted this very thing. I find it hard to justify why I'm not doing this.
Out with the old, in with the new! Now that I have all of the original electronics out of the back I can begin remodeling.
The new unit is a shottky diode rectifier (converts 3 phase AC to DC) and Meanwell power supply that can provide a continuous 53 amps DC, more efficiently than the original DC-DC. The Meanwell's internal bridge rectifier is bypassed currently to increase efficiency.
![](https://i.imgur.com/Rf9tR7r.jpg)
07-27-2018, 05:41 AM
#88 (permalink)
Vekke had a thread about it. He was getting 2l/100 km at 100 kph with pulse and glide.
If you could put the 1.2tdi and keep the battery that would be awesome. And build a bigger pack like robert Murray-smith. That would be my dream car.
07-27-2018, 11:07 PM
#89 (permalink)
I appreciate having seats with removable head-rests - I can close the hatch with an 8ft board inside now.
Something new in the works:
![](https://i.imgur.com/sNcSi3i.jpg)
07-28-2018, 04:00 PM
#90 (permalink)
Laid down some sound dampening and started building up my rear deck. 120 amp breaker protecting the battery, 2 gauge wiring to the front, re-organized the fuse box so it makes sense with the battery relocation.
![](https://i.imgur.com/AuPuT1n.jpg)
