Old 11-02-2010, 05:40 PM   #1 (permalink)
johnnymac's Avatar
Goldie - '99 Ford Escort el cheapo
How can I reset a scangaugeII
Scangauge thinks I used 18 gallons when I filled up. It was removed from my old vehicle and stuck in a drawer for 6 months. When I filled up it thought I put in 18 gallons. When I corrected it to 9.7 it changed it a bunch of %( I don't remember exactly)I mean drastically like 68%. I have a 99 Escort with a 13 gallon tank and the scangauge says I have 1900 miles til empty. Please help. Also, the SG does not want to come on in the morning, it flickers on and off. In the afternoon when I get out of work it fires right up. ??
Going by my trip meter I went 380.8 miles on 9.7 gallons, I figure I got 39 MPG.
Thanks all
John
2006 Pontiac Vibe 36 MPG 5 speed
1999 Ford Escort Base Model 2.0 5 speed
Scangage II
WAI
FULL disc wheel covers
Sears Guardsman plus tires 44 PSI
Best tank 42 MPG 244K
Old 11-02-2010, 10:44 PM   #2 (permalink)
...beats walking...
...read the paragraphs about "resetting" the unit back to original factory 'vanilla' settings.
The Following User Says Thank You to gone-ot For This Useful Post:
johnnymac (11-03-2010)
Old 11-03-2010, 11:33 AM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
It doesn't know what car it's in, so it thinks it's still in the other car .
As Old Tele Man says, reset it to stock first, and then enter the correct engine size in its settings.
You also need to calibrate it a bit after the next fuelings.
According to the manual, the display doesn't like being too cold or too hot - but the operating range is 0F to 160F.
The Following User Says Thank You to euromodder For This Useful Post:
Old 11-03-2010, 05:47 PM   #4 (permalink)
johnnymac's Avatar
OK, I just moved to a new house and all of my stuff is in the Twilight Zone. I might find it in a week or two or three..
Thanks all
Scangage II
WAI
Old 11-03-2010, 08:53 PM   #5 (permalink)
johnnymac's Avatar
Thanks guys. I bought gas yesterday and was getting incredible readings on it so when I got home from the fillup, I saw the default setting on there and reset it. I did not know that was all there is to it. This morning going to work, it seemed a little closer than it was so I think I'll just do a couple of regular fillups and I'll bet it will be OK.
I have been riding a motorcycle since August so when I bought this cream puff escort with 206K I couldn't wait to hook up the gauge and I got in a hurry. Nice car, nice gauge. NICE HEATER. 39 MPG first fillup. A good starting point to start ecomodding.
Scangage II
WAI
How to reset ScanGuage Fill-Up? GoodOak Instrumentation 2 05-07-2010 03:21 PM
ScanGaugeII for sale $129.95 Like New JayC For Sale 5 05-31-2009 09:15 PM
Mpguino does not time-out or reset. randerson0248 OpenGauge / MPGuino FE computer 8 03-09-2009 05:07 PM
Reset / Lockup issues - causes? gascort OpenGauge / MPGuino FE computer 4 12-19-2008 04:57 PM
ScangaugeII Problem FordClassicCars Instrumentation 1 09-09-2008 07:40 PM
