Old 04-19-2014, 09:36 AM   #1 (permalink)
Black sheep 2013 - '11 Volkswagen Jetta S
90 day: 29.01 mpg (US)
black sheep 2014 - '11 volkswagen jetta trendline plus
90 day: 29.78 mpg (US)
Black sheep 2015 - '11 Vw Jetta mk6
90 day: 22.42 mpg (US)
How long can gasoline last in a tank
I have heard mixed results from one month to one year, the volt will burn off its fuel tank after 1 year automatically, to reduce corrosion and particle build up. Will the grade of gas affect its longevity.
I'm using regular and I'm 4 days away from my fuel sitting for a month
Old 04-19-2014, 10:12 AM   #2 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
My Jeep goes 6+ months (still has fuel from October in it!) between refuels and has never caused a problem. Some Eco cars will easily go 1000km on a tank which for many would be a whole month's driving (if not longer).
But look forward to differing opinions.
Old 04-19-2014, 11:39 AM   #3 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Mustang uses month old E0 fairly often now that I have a second vehicle. Haven't seen any issues so far.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 04-19-2014, 11:41 AM   #4 (permalink)
The sealed vapor recovery systems in modern cars can keep gas "fresh" for a long time as long as they remain sealed. My VX sat for 15 years and started and ran fine on E0 gas. I did immediately refill the tank. Modern E10 gas will not last anywhere near that long and I would agree with the Volt using up fuel that has been in the tank a year.
It's a different story with unsealed containers, much shorter time period.
regards
Mech
dmafanp (04-20-2014)
Old 04-19-2014, 12:11 PM   #5 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
The most experience i have with fuel age is in lawn mowers, people will say not to let the gas sit all winter or it won't start. That's garbage. If you fill a push mower with gas that was purchased in April then leave it all winter and try to start it next April, yeah you will probably have issues. But if you only buy a gallon or two at a time then the gas you buy in September will be just fine in April.
Long story short, my opinion is that 1 year is the maximum. But with a good detergent added you can still use it.
Old 04-19-2014, 12:16 PM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
What Old Mech said.
7 year old gas in my Firefly when I got it. Ran fine.
My Swift GT parts car has 5-7 year old gas in it now, and always starts right up.
However: 1 year old gas in my old 2-stroke boat engine is iffy.
See also: http://ecomodder.com/forum/showthrea...use-19021.html
Old 04-19-2014, 12:41 PM   #7 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I had a similar experience to Frank.
I had a '59 Austin Cambridge that sat in a garage for over 25 years, it also fired right up.
2000 Insight MT 106K Citrus A/C
Old 04-19-2014, 01:11 PM   #8 (permalink)
My camaro satfor 3 years, fired right up after I put a battery in it.
It did run better after I topped it off with fresh gas.
Old 04-19-2014, 01:21 PM   #9 (permalink)
Old leaded gas would last even longer, but vapor recovery systems were not sealed back then.
regards
Mech
Old 04-19-2014, 01:22 PM   #10 (permalink)
I drain gas after 3 months and put it in the wifes car.
regards
Mech
