Old 11-02-2010, 10:18 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
The Show Off Your Cockpit Thread
This thread is for anyone who wants to show how they've Feng-Shuied their cockpit to ease hypermiling.
When I started ecomodding a while back I kept wondering about how and where to attach all the buttons, switches and LEDs in a way that is both functional and wife-approved. Luckily, the CD changer under my radio was kaputt, so I removed it to (1) use less electricity, (2) keep it out of the reaches of anyone who might want it. (Actually, I don't mind someone taking it, but I don't want to replace my window in the process.) So I used the space under my radio for my ecomodding console, and now that it's more or less done I'd like to show it off so that others may get some inspiration.
I used the carcass of a dead radio to make sure everything would fit nicely.
Starting from the left:
  • A mom-off-mom switch for engine starting and stopping,
  • An on-off switch for the alternator (not used),
  • Two mom-off-mom switches for opening/closing the two active grille blocks,
  • An on-off-on switch for the DRLs (on-off-auto).
There is also a small blue LED to signal when the DRLs are on, and a larger blinking red LED that was supposed to signal when the radiator fan kicked in, but now only signals when the engine kill button is pressed. There is still room for another two switches when the time comes.
The insides (pardon the mess) are wired through connectors which allow the whole box to be easily taken out of the car (and worked on in a warm, dry place). I plan to get the mess cleaned up and add a small diagram of which wire show go where, in case my failing memory gets the better of me.
My ScanGauge rests in on the ashtray, under which is the OBD socket.
I'm thinking about a semi-clear piece of plexi, hinged at the top, to cover the buttons from curious eyes and fingers when I'm not driving.
And here's the start/stop button in action.
ID:	7265   Click image for larger version
ID:	7266   Click image for larger version
The Following User Says Thank You to Piwoslaw For This Useful Post:
SVOboy (11-03-2010)
Old 11-03-2010, 12:20 PM   #2 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Congrats for the cleanness of your switches box at least when it's closed
Sadly I don't have a free space to cleanly mount my switch
May I open a "Show off your ugly cockpit" thread ?
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 11-03-2010, 12:34 PM   #3 (permalink)
...beats walking...
...how does that saying go? "...NEATNESS is next to..."
Old 11-03-2010, 04:18 PM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
Oh, c'mon Groar. First the Uglyback, then the Uglycover and Uglyteeth, now the Uglycockpit. Where is your self esteem??
mcrews (11-21-2010)
Old 11-03-2010, 07:35 PM   #5 (permalink)
The PRC.
My travelling environment, glad I gave it a quick hoover last week
Anyone want to play spot the VAG part ? The wheel is an obvious one... Note I drive on the correct side so the wheel is on the right, and mods seem to be at a minimum. But wait, there is an SG2 poking its head over the steering column.
Why yes, there it is. Note that the SG supplied sticky pad has long since given up so I replaced it with one intended to stick number plates onto the outside of the car, but as you can see the toxic state of my interior has made it fail.
No it wasn't as late as the clock suggests, I must work out how to change it for GMT after BST.
All of this looks neat until...
Yes I did take a Dremel to my dashboard to get the wiring to fit. I actually got fed up of banging my knee on the door to this cubby hole.
I did miss out a pic of the insulating tape holding this cover closed, but you get the idea.
ID:	7271   Click image for larger version
ID:	7272   Click image for larger version
Old 11-03-2010, 08:26 PM   #6 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
@Arragonis:
Ah, so much better.
Here's my toggle switches, which fill space formerly occupied by blanks in all North American Insights. From left to right, it's fuel injectors, clutch switch (assist/regen disable), DC/DC converter, and MIMA enable. The only one I use with any frequency is the one on the far left, which enables EV mode, forces DFCO, or just does light anti-theft duty.
This is the only picture I have of my MIMA display, which is just eleven LEDs wedged between the steering cowl and the dash.
Pictures of my ScanGauge, MPGuino, and BCMGauge will have to wait until the latter two are installed. I also have a momentary kill switch on the gearshift and a MIMA joystick + 2 buttons zip-tied to the handbrake lever.
Name:	Dash3 - thereifixedit.jpg
Old 11-03-2010, 09:22 PM   #7 (permalink)
LOL, Robert you need some gas and juice in that thing.
regards
Mech
Old 11-03-2010, 11:49 PM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Looking nice guys, hopefully I can dig up a photo of where I left the IRX when I split from the country
Old 11-04-2010, 12:48 AM   #9 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
I'm still looking for the "Mom-off" switch... where do you find one of those? And do they really work? My Mom can be a bit annoying when I EOC...
Old 11-04-2010, 02:45 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
Originally Posted by RobertSmalls View Post
@Arragonis:
Ah, so much better.
LOL, you beat me to it!!
Actually, the only Mom-off I've heard about is the permanent variety Notice mine are Mom-off-Mom, so going from Mom to off brings Mom back sooner or later... Mom is never too far away...
The Enclosure Thread, Show Yours Off!! americasfuture2k OpenGauge / MPGuino FE computer 87 04-24-2016 01:45 PM
2010 Washington Auto Show: "A Green Machine" - Jan 27-31 MetroMPG General Efficiency Discussion 10 01-30-2010 07:40 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
