04-11-2023, 03:06 PM
Looking for Fuel Saver Kit testers
Thanks for having me and be able to join your community, As you probably know one quart of gas needs around 15,000 quarts of air to burn (a man uses 15,000 quarts of air per day, so saving one quart of gas save the air for one man for one day).
I'm looking for drivers ready to test a new technology to save fuel and reduce pollution.
Already available on the European market, focus in vineyards equipments, it's now available in the US and we are looking for drivers to test it on US vehicles, more convenient if you live in Florida (East coast) to install it.
No engine modification required, installed before the air filter.
Contact me if you're interested.
04-12-2023, 09:45 AM
Focused on MPG
This sounds very generic, what are the fuel tester kits supposed to do, how do they work, what do they look like?
Any links or videos?
Staying Focus'd on MPG
04-12-2023, 11:16 AM
Thanks for your request, you're right, our device is very generic, working on all combustion engines, broilers, incinerators, furnace and all apparatus requiring air to burn.
This new technology is about qualifying a fraction of the incoming air through bio materials, to modify air structure creating a tensio-activity, with a ferro-magnetic charge, guided by an amorphous material. The mission is to « scratch » the air and energize the hygrometrically saturated air.
The full description and patent is available on our web site EcopraUsa.com
Let me know if you have more question after visiting it.
04-12-2023, 01:17 PM
...qualifying a fraction of the incoming air through bio materials, to modify air structure creating a tensio-activity, with a ferro-magnetic charge, guided by an amorphous material.
Won't visit until you define or explain the bolded terms. - qualifying
- air structure
- tensio-activity
No need to explain <<scratch>>ing air. At all.
04-12-2023, 02:54 PM
How does it counteract the induced thermostatic quantum shift in ionized charged plasma though? I mean, you'll get a runaway exothermic phase misalignment of the hydrocarbon nuclei, which you don't need me to explain how disastrous that would be.
04-12-2023, 05:39 PM
Focused on MPG
04-12-2023, 06:58 PM
You are the one that touched the tar-baby*. The thread lay there quietly until you responded.
*Cultural reference.
Tar-Baby
The Tar-Baby is the second of the Uncle Remus stories published in 1881; it is about a doll made of tar and turpentine used by the villainous Br'er Fox to entrap Br'er Rabbit. The more that Br'er Rabbit fights the Tar-Baby, the more entangled he becomes. In modern usage, tar-baby refers to a problematic situation that is only aggravated by additional involvement with it. More at Wikipedia
04-12-2023, 08:20 PM
If you soak the tar-baby in gasoline, will the resulting mixture better atomize and lead to more complete combustion?
04-13-2023, 03:21 AM
#9 (permalink)
EcoModding Noob
I noticed on your website you claim that your product
will help your engine to reduce smog emission by 50 to 70%.
do you have any independent certified/published test results that prove this? Other than a low-res "before" and "after" photo on your website?
It honestly seems that your goal is to generate sales by using big words and science-y language... Shown below is another snippet from your website's "patent" tab. Am I wrong?
1- Collecting air by the front grille through a stainless hosepipe (also used to refill the evaporator if necessary).
2- The Evaporator is increasing hygroscopicity value to produce the best active air through bio materials like ceramic, to modify water structure creating a tensio-activity,
3- The next step is to go through the reactor, with a ferro-magnetic charge, guided by an amorphous material. His mission is to « scratch » the air and energize the hygrometrically saturated air.
4- The Engine suction will create a vacuum turning on and off this device.
You also claim on your website that your product is both
transferable from one vehicle to another in minutes.
and
Estimate installation time 1 to 2 Hours
So why would we need to be located on the East Coast? Can't we install it ourselves?
One final note, you have a big "Edison Awards 2023 Nominee" badge on the top right corner of your website, yet I find nothing on their website listing your product as a Nominee. https://edisonawards.com/nominee-gallery
Reason: formatting + missed point
04-13-2023, 03:33 AM
#10 (permalink)
You also claim on your website that your product is So why would we need to be located on the East Coast? Can't we install it ourselves?
You win the Edison Awards for patience and thoroughness.
I went straight to mockery.
