Old 12-22-2011, 02:16 PM   #11 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mbrac View Post
Thanks everyone for your input - I think I'm going to try cleaning the Idle Air Control Valve - since it's only affecting it when coasting - if that dosen't do it - I'll just replace it- cost from Autozone is $54 - no error codes - just noticed it since I became an ecomodder...
I recommend avoiding throwing parts at the problem. I did that once, and hopefully I'll keep my patience and never do it again. If cleaning the IAC does not work, test and troubleshoot before committing to a parts purchase. If you replace the part and the condition continues you will kick yourself for the lost cash and the unnecessary work. Do you have the service manual?
This novice's 2 pennies. Good luck!
Old 12-22-2011, 07:40 PM   #12 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
On my 98 Pathfinder, if I leave it in gear with the clutch in it will idle at 12-1300 rpm while coasting, if I shift to neutral it drops to about 650( once up to normal temp).
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 12-22-2011, 08:34 PM   #13 (permalink)
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Perfectly normal (unfortunately). Last time my employer gave me a focus to drive to...GM training and it did the same. It was automatic and even at 75-80 MPH when I put it in neutral,the RPMs stayed exactly where they were in D at that speed. (idled at 2000+rpm) As vehicle speed declined,so did the rpms to where I pulled it back to D the tac hardly moved as it seemed to rev match.
It has got to be an intentional ECU mapping. I thought it was annoying but never thought of it as abnormal.
Barna
Old 12-22-2011, 08:35 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
fwiw, my 97 saturn likes to idle high when the car is moving and races a little on restart. I just waited till it was idling at about 1000rpm when warmed up and then unplugged the idle control valve. Takes a little extra footwork while it is warming up but otherwise it is perfect now.
Old 12-22-2011, 11:12 PM   #15 (permalink)
a lot of car do this
the idle speed is higher to avoid engine stall in case of hard braking
the ecu need the speed sensor to do this
0 mph = normal idling
by the way, if you coast to a stop let the car in fifth gear the engine goes in fuel cut off it is better for economy than idle
Old 12-24-2011, 12:11 PM   #16 (permalink)
tru
tru - '05 Ford Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 GMC Sierra Denali
that is not true for the focus, at least an 05' manual
Old 12-24-2011, 12:20 PM   #17 (permalink)
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
mbrac, does it idle this way consistently, or is it at all affected by engine temperature?
Mine will idle higher in really cold temps while the engine is below operating temperature.
Edit: It's not a Focus, but I figured any clues might help.
EcoDriving: Turning more fuel into usable forward motion.
Old 04-14-2012, 02:31 PM   #18 (permalink)
EcoModdingRealist
SiVX's Avatar
The Blue Lagoon - '92 Honda Civic VX
All cars idle higher in colder temperature. The oil hasn't warmed up so it is thicker, there is more strain on the engine and a bunch of technical stuff that is way over my head. The point is, yes at first start and cold engine temps the car will idle higher. Always
[ACHV ALL]
Old 04-14-2012, 04:38 PM   #19 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
my matrix idles at about 900rpm but I rarely idle it. I have a kill switch and use it regularly.
