05-22-2016, 03:06 AM
#2031 (permalink)
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
05-22-2016, 12:23 PM
#2032 (permalink)
^^ What's that first one, a T-bird?
https://www.google.com/search?q=tran...stellungswagen = Exhibition Car
The right-hand running light must be for illuminating the roadside ditch.
05-22-2016, 01:05 PM
#2033 (permalink)
^ That must be an Adler 2.5 Autobahn, so called because it could do maintain high speed on the then new Autobahn stretches in Germany.
![](https://images.spritmonitor.de/544051_25.png) lifetime FE over 0.2 Gmeter or 0.13 Mmile.
![](https://ecomodder.com/forum/fe-graphs/sig7127a.png)
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
05-22-2016, 04:44 PM
#2034 (permalink)
CFECO
The problem with the solid truck would be turning radius. Even with both front axles steering, they don't turn as sharp as a full semi tractor-trailer which can make a u=turn in the length of the trailer + about 4'. It sure seems that moving panels could be done to fill the tractor-trailer gap.
05-23-2016, 01:40 AM
#2035 (permalink)
Laws don't allow overly long rigid vehicles, so such design would compromise capacity. In most of the world you can't have more than ~12 meters lorry or a trailer (though f.e. Sweden allows up to 24 m) and from the limited data that I saw, that's the most popular trailer size.
Though not all payloads are volume-limited and I guess there would be place for such truck too.
Laws aside, wouldn't steering rear wheels work well?
05-23-2016, 11:11 PM
#2036 (permalink)
Frankly that is the exact shape I was actually going for with my canopy couldn't figure out how to make the negative curvature on the sides where the single piece of shrink wrap looking for advice on how to achieve that shape
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
05-24-2016, 12:23 AM
#2037 (permalink)
Chop that bit off an old Riv.
05-24-2016, 12:16 PM
#2038 (permalink)
gumby79 -- Take a sheet of material (aluminum, fiberglass or Polymetal) the length and height of the side, twist it and cut the top curve. If it doesn't match the contour it will improve it. Maybe.
Technically, it's a sector of an hyperbolic paraboloid.
05-27-2016, 12:20 PM
#2039 (permalink)
Hanomag Diesel
The Following 2 Users Say Thank You to sgtlethargic For This Useful Post:
05-27-2016, 05:51 PM
#2040 (permalink)
Hanomag
