Old 05-27-2008, 03:50 PM   #1 (permalink)
SirKeats's Avatar
GeRide - '89 Geo Metro *XFi
90 day: 54.26 mpg (US)
Just confirming - warmer air on EFI
From the looks of the posts on warm air intake on an EFI engine (such as my '89 metro)... it does not result in a significant increase in mpgs. Is that correct?
Just wondering if I should disconnect the ducting currently in place from the passenger-side wheel-well to the air-filter housing or not.
Based on what I've read, it doesn't look as though this would help me any in my EFI engine.
Sound about right?
Old 05-27-2008, 04:35 PM   #2 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
I've been looking at this too, and I think the concensus is that you have to try it yourself and see what happens. I think some cars can have hotter air without retarding timing but others retard with a WAI canceling any benefits.
My Neon has a warm air intake stock pulling air from the middle of the engine bay, the scangauge tells me this tends to be 50F higher than ambient on the highway. I was thinking of ducting it so the intake pulls through the rad directly probably making the intake temp 90 or 100F over current temps. I'll have to collect some data on the ignition timing, rpm, TPS, and current temps and then try the switch to hotter air.
Ian
Old 05-28-2008, 02:31 AM   #3 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Precisely. It requires testing to each engine's ECU mapping to gain a perspective. Most brands differ, so it's up to the user to test hot, warm, and cold air for FE changes. The A-B-A method is preferred, as this method insists on comparing the the change vs. baseline, under similar conditions, and are reproducible. Essentially the "Scientific Method" is what sets us apart from "quick fixes" and scams.
If this is done, we encourage sharing of the results
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 05-28-2008, 08:32 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
That was the first part of my weight reduction program
I removed the hose, the adapter on the cleaner housing, and all the ducting from the fender well. I cannot say if this made anything bettor or not because I simply don't notice, but the engine sounds better in my opinion.
I found a video about this. Here you go.......................
GeoMetroforum.com - got mpg?
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
