Old 01-31-2014, 07:21 PM   #1 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Stealth (Invisible) Grill Block
Well, while I'm still working on the smooth clear wheels, I have the lexan laying around. I haven't found a good way to cut a perfect circle 18.5" wide just yet. But, I have found that tin snips work excellent for cutting (roughly) straight lines. So here it is:
I took multiple pictures, and these are the two where it's most visible.
You can also see the block heater plug hanging down beneath the bumper. Might relocate it.
It's 1/4" thick and covering the entire bottom half of the grill. I know the top grill is usually whats recommended, but with this car the fan seemed to run too much while I blocked it.
Just need to round the edges a bit to match up with the curve of the bumper, as right now it sticks out slightly. Probably the only thing obvious in this picture is I wiped the salt off the front bumper before I installed the block itself.
ID:	14539   Click image for larger version
The Following 5 Users Say Thank You to brucey For This Useful Post:
aerohead (02-01-2014), ecoTex (01-31-2014), mcrews (04-28-2014), poomanchu (02-01-2014), RobbMeeX (02-01-2014)
Old 01-31-2014, 09:52 PM   #2 (permalink)
XYZ
How did you attach it?
1/4" lexan is quite thick a material to use, and not very flexible. I suggest that you try aluminum trim coil, used for trim in siding on houses. It's very easy to cut with snips and it will bend for contours in a grille. It weighs almost nothing, and it won't rust. It's excellent for fabricating belly pans, too.
If you want it to be invisible, simply spray paint it black.
Old 01-31-2014, 10:06 PM   #3 (permalink)
A madman
brucey's Avatar
Hardly visible, but 24" zip ties hold it to the factory grill.
I was considering U bolts with wing nuts for a long term solution, but going to try to get the corners molded correctly first. (Will post pictures tomorrow.)
The Following User Says Thank You to brucey For This Useful Post:
Old 02-01-2014, 06:44 AM   #4 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Nice job! The tire look pretty wide might benifit from some air deflection.
Old 02-01-2014, 10:08 AM   #5 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Use a band saw.
Drill a hole in the center, Place a dowel in said hole into a board. Clamp board to table so it is 18.5"/2 (9.25") away from saw blade. Rotate the lexan with blade running. Can be done without a hole being drilled by use of adhesive, but might become unstable.
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following 2 Users Say Thank You to Superfuelgero For This Useful Post:
aerohead (02-01-2014), Neen (02-04-2014)
Old 02-01-2014, 01:07 PM   #6 (permalink)
Civic Type-DX - '97 Honda Civic DX
90 day: 40.3 mpg (US)
Looks fantastic I really like this! I might try to do the same with plexiglass as I can't afford the Lexan
Or the OP can just use what is being shown, without resorting to using house siding that flaps in the wind as it is already cut and mounted? I don't know, I always thought clear is a bit more invisible than an opaque coating
Old 02-01-2014, 01:33 PM   #7 (permalink)
A madman
brucey's Avatar
I got a good deal on some blemished lexan. The glue doesn't adhere properly so taking the protective coating off is a pain, but as you can see it looks fine once you DO get the coating/paper off. Plus I developed a new technique of removing.
It was actually about the same price as plexiglass. I wonder if the seller still has it available. Will check into it.
Here is a daylight picture, lot more obvious since the reflection doesn't match. Is there such a thing as matte reflective lexan?
aerohead (04-29-2014)
Old 02-01-2014, 04:07 PM   #8 (permalink)
XYZ
If you fasten it properly, sheet aluminum won't "flap in the wind" any more than any other material might. Considering that a radiator is basically black, and that most grilles are either chrome or black, you won't notice a grille block that is black.
The Following User Says Thank You to XYZ For This Useful Post:
Old 02-05-2014, 12:50 PM   #9 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Here is a pic of a Cruze diesel with factory grill blocking: 2014 Photo Gallery
...very interesting how this is making its way into main stream quietly.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
The Following User Says Thank You to LeanBurn For This Useful Post:
aerohead (02-05-2014)
Old 04-28-2014, 02:35 PM   #10 (permalink)
A madman
brucey's Avatar
Worked on it a bit now that the weather is nicer. Sets a lot more flush since it's actually inside the grill now.
Now to finally get around to those wheel covers.
