Old 09-22-2011, 06:55 PM   #101 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
A couple of percent is not even detectable without highly accurate instrumentation. I know; I've tried it.
Sure, the small reductions in fuel use are hard to spot.
But in order to significantly reduce the Cd on production cars, we're going to need a miracle aerodynamic breakthrough, or we're going to have to apply all those 2% ecomods.
The better it already is, the harder it is to improve upon.
Loremo is but one example of a low Cd skirtless design and at .20 it's well below .25.
Unfortunately, it's a prototype value as there's no production so far.
Old 09-22-2011, 09:28 PM   #102 (permalink)
We mainly need to just get people out of SUVs and pickups.
Old 09-22-2011, 09:41 PM   #103 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
To get me out my Super Duty, somebody is gonna have to make something other than FWD automatic transmission midget-mobiles.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-22-2011, 11:21 PM   #104 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
You know that's not going to happen in America until gas goes sky-high again.
Who said this was automatic? Most of the cars on this forum are manuals, and the Strømlinet Vogn is no different (although it will be offered with an automatic).
I can't help you with the RWD thing. You might have to buy a sports car
Old 09-23-2011, 04:49 AM   #105 (permalink)
The PRC.
Quite a few people do.
If you are still planning on using the Aygo/iQ power unit there is a 5MT option - kind of a simpler version of the DSG style semi / full auto thing in VWs.
I'll just park this here.
Old 09-23-2011, 09:50 AM   #106 (permalink)
My theory applies to Michigan and it's pot holed roads, add in some wet snow and the SUV and Pick-Up trucks make total sense.
Better roads and you could see a return to cars in lieu of light trucks.
Take the power steering, power brakes and 7 second 0-60 times out of that segment and watch it die a fast death.
Old 09-23-2011, 12:36 PM   #107 (permalink)
Sven7's Avatar
I am, thanks. Does it have a clutch, though? Because that's half the point of a manual.
Those are still FWD, silly. Well, some are AWD but those were more expensive. No one makes RWD economy or midsize cars anymore- they're all luxo or sport rockets. Then again, there's always the BMW E30. Dave, have you considered an E30?
Sorry, but i'm tired of hearing that excuse. Jesse "The Mind" Ventura tried to tell us his Hummer H2 purchase was because of Minnesota winters. We all know that was baloney. I drove my lowered Rabbit through the entire last winter and the only time I got stuck was purposefully driving into about a foot of unplowed snow during a snowstorm. Even then I'm sure if I had more than 4 inches of ground clearance it would have been fine.
All you need in the snow is skinny tires and weight over the drive wheels. 4WD is for off-road trails.
Easy peasy.
The Following User Says Thank You to Sven7 For This Useful Post:
darcane (09-23-2011)
Old 09-23-2011, 12:41 PM   #108 (permalink)
Sven7's Avatar
Old 09-23-2011, 12:55 PM   #109 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
How about this? It is the light pick-up version, of my propane-electric X-Car series, obviously the Photoshop rendition here. This truck has, an extendable bed which can be pulled out to accept 4x8 sheets of plywood, 1/2 ton capacity, a retractable bed cap, and a "5th wheel" centered between the rear wheels with it's own air spring, to compensate for load changes. The rear seat and bulkhead also folds down for max bed length. AWD would be an option by putting the electric drive on the front wheels, and since the vehicles have air suspension, it would be easy to raise the vehicle height for extra ground clearance.
Old 09-23-2011, 01:33 PM   #110 (permalink)
darcane's Avatar
Easy peasy.
Yeah I hate the "I need 4wd because of snow" too. I've been in some nasty conditions (spent many winters in Alaska) and never needed 4WD.
Almost ANY car is fine in the snow as long as you have good tires. Experience in driving in the snow makes a big difference too. There are very few places that your typical FWD econobox can't get to with just a set of good snow tires (with studs if you encounter ice regularly).
That said, I'd much rather drive a RWD. Dry, wet, snow, whatever. I greatly prefer the handling dynamics. Unfortunately, there are very few RWD economy cars.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
