Old 08-25-2010, 01:11 PM   #11 (permalink)
Yeah that looks good. You will have to make that a momentary switch though. The actuators, when powered just continue to try to go. Eventually they'll overheat and die. So, you'd need to flick the switch for 1-2 seconds and then let go.
Old 08-25-2010, 01:29 PM   #12 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I was drawing that up assuming a 3 position (duel action) switch with the middle being open (off). If I can not get a duel action one I can just use 2 singe (3 position) switches.
About the pivot and arm, can you draw something up after work (I am a visual guy, so I need picts).
Old 08-25-2010, 01:43 PM   #13 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Weather Spotter View Post
....I am thinking of a sliding door with slots (but that is just at the moment)....
The sliding door approach is fine if you don't need more than 50% of your radiator area remaining for cooling.
No matter how a sliding door arrangement is configured, the maximum remaining flow area is only 50% of the original.
Just something to keep in mind with this type of design.
I personally favor rotating slats. It gives you closer to 100% flow area depending on how thick the individual slats are and how many, but is more complicated to fabricate.
When I do an adjustable cooling duct, it will be with slats.
Jim.
Old 08-25-2010, 02:04 PM   #14 (permalink)
Wiki Mod
How about doing a rotating door. have it rotate along the long axes at the middle of the door have two actuators with wire wrapped around a pulley. when one is out the other is in. Then it will pulling open or shut. when open it would be parallel to the ground.
Would that work?
If I stay with the slats, if I make two sliding doors stack on each other, I could have each open 1" for a total open of 2" for each 1" of blocked off space. That would give me all closed, 1/2 open or 2/3 open.
Old 08-25-2010, 02:24 PM   #15 (permalink)
90 day: 51.82 mpg (US)
That would work. The Chevy Cruze ECO's automatic grille shutters rotate on an axis, and they're even foil shaped, so more aero friendly when in the open position.
see Cruze grille block discussion starting around post 106 here: http://ecomodder.com/forum/showthrea...4-a-11229.html
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Cd (09-23-2010), Weather Spotter (08-25-2010)
Old 08-25-2010, 03:12 PM   #16 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I made two independent sliding vents, each with a power lock motor. But my diesel doesn't need more than 50% of the opening.
The Following User Says Thank You to Piwoslaw For This Useful Post:
mcrews (11-16-2010)
Old 08-25-2010, 03:22 PM   #17 (permalink)
Wiki Mod
How did you attach the lock motor to the grill block?
Old 08-25-2010, 03:27 PM   #18 (permalink)
aero guerrilla
Piwoslaw's Avatar
The grille block itself is attached to the car's grille, as are the lock motors. The sliding part is attached to the motor with a short piece of metal (aluminum left over from skirts), with screws at each end. I'll try to get a close up picture of it tomorrow.
Old 08-25-2010, 03:31 PM   #19 (permalink)
Wiki Mod
thanks, pics help me a lot. once I see what I need to make I can do it!
Old 08-25-2010, 03:33 PM   #20 (permalink)
...beats walking...
...a small, light-tension spring and a 12VDC solenoid might also work.
Arduino controlled automatically actuated grill block Daox Aerodynamics 167 11-08-2016 11:23 AM
Piwoslaw's Peugeot 307sw modding thread Piwoslaw EcoModding Central 295 03-28-2016 03:25 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
