Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 08-24-2022, 09:31 AM   #31 (permalink)
Is it actually a DC field or is it electonics switching at that frequency. Aka pulsed DC? Other than hundred of voltage doublers it's gonna need magnetics which require switched field
aerohead (08-25-2022)
Old 08-25-2022, 01:47 PM   #32 (permalink)
candle flame
Originally Posted by Logic View Post
Hmmm!!!
A candle flame burns higher when magnets are slightly below it, causing more O2 in the flame area..?
https://youtu.be/dX2R4hRAYMc?t=489
Perhaps, the proximity of any solid structure near the flame, simply modifies the aerodynamics of the convection current as the hot gases rise, 'boosting' the flame, a phenomena not necessarily limited to magnetic structures.
( the answer is hiding in plain view? )
Old 08-25-2022, 02:00 PM   #33 (permalink)
something simple
I believe cryo processing is how the bottled oxycen one buys is made aerohead.
NOT practical or cheap.
But one may just be able to get the O2 percentage up a bit with properly arranged magnetic fields or a centrifuge of some sort, or a combination of the 2.
So something simple and light that increases the % of O2 inducted into an engine would be nice.
You'd have to do a complete energy balance, comparing the OEM thermal efficiency, to that of the modified engine, including the energy requirement to 'free' oxygen from atmosphere.
We want to reduce entropy, not aggravate it.
Old 08-25-2022, 02:12 PM   #34 (permalink)
The best way to separate oxygen is with membranes.
Old 08-25-2022, 04:33 PM   #35 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
How well does membrane technology compare to zeolite technology? I was under the impression that membrane tech uses less energy but makes less pure oxygen, more like an O2 concentrator than O2 N2 separator.
Old 08-25-2022, 04:45 PM   #36 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
In terrestrial conditions it has long been believed a microscopic set of oppositely charged and magnefied plates could be used to concentrate “polar substances “ in a liquid/gas towards one plate allowing you to separate them using minimal power
This could be used to remove some of the salt in water or some of the co2/water vapor in air
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
aerohead (08-25-2022), Logic (08-26-2022)
Old 08-25-2022, 04:57 PM   #37 (permalink)
towards one plate.........
Electrostatic precipitators function that way. Air is induced past an array of anodes or cathodes and any polar molecule present in the airstream will be attracted to one or the other, and adhere, until purposely removed.
Logic (08-26-2022)
Old 08-26-2022, 06:41 AM   #38 (permalink)
I did a quick search, but no luck finding info on this.
There a re a few patents about concentrating O2 with magnets, but the para/dia magnetic forces is so small I don't see this idea working to any useful degree.
Old 09-09-2022, 06:52 AM   #39 (permalink)
Patent:
Gas separator for providing an oxygen-enriched stream {using low-energy ionization}
https://patents.google.com/patent/US7318858B2/en
Old 09-10-2022, 08:13 AM   #40 (permalink)
As of a while back, there is no requirement to prove your patent functions or have a working model. Appears to be more of a copyright than anything else.
