Old 10-06-2009, 06:39 PM   #11 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
That rotor was out of the 15hp motor, the stacked one was a complete motor that apparently had 2 or 3 of those in there, but he wouldn't let me take it apart.
The complete single rotor 15hp motor was about the size of the normal 8hp e-tek motor.
Originally Posted by Christ View Post
Not quite what i was thinking of... When you said multi-rotor, I was thinking something more along the lines of several of those things in your hand stacked together on a single armature, and a 2 piece housing bolted around them with coils that stick down in between each rotor.
Kind of like this:
Where | is part of the housing, and : is one of the rotors.
Old 10-06-2009, 07:03 PM   #12 (permalink)
PSmodder lurker
Similar to this? Here's Lemco's 2x2 installation dwg.
http://www.lmcltd.net/uploads/docume...stallation.pdf
I'm sure custom multiple motor installation brackets could be arranged.
Old 10-06-2009, 07:07 PM   #13 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
OK, so maybe it was the same design, then... How fond are you of B&E charges and jail time? I MUST SEE THAT MOTOR!!!
LOL - I jest.
Old 10-06-2009, 07:21 PM   #14 (permalink)
That's the basic idea, except not using magnets/coils arranged on the outer surfaces of each rotor. Instead, you're using the outermost area of the face of each rotor, putting either magnets or coils on it, then facing it off with part of the housing that has the opposite.
If this will help you imagine it -
The rotor will go between each of the red "things" in each housing section.
Name:	rotor motor.jpg
Old 10-06-2009, 07:37 PM   #15 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
The Etek is based on a Lemco design that B&S licensed. I think Lynch is still selling the original Lemcos, which were more powerful.
Old 10-06-2009, 08:36 PM   #16 (permalink)
...beats walking...
...anybody know what the Patent Number is for it? I'd like read the "claims" made and filed.
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Interviewed and Drive Test with Newspaper Reporter Today! Matt Herring Success Stories 21 08-03-2009 09:12 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
Put in Mobil-1 and tufoil today regor EcoModding Central 11 08-26-2008 02:09 PM
