06-07-2013, 11:12 PM
#191 (permalink)
I bet adding those would probably help the U.F.O.'s aero, and if doing so means the underside of the tail then technically becomes a diffuser (if un-befinned), so be it!
Difflow use 5 -7 fences. I suspect they channel turbulent air and equalize it across the rear.
06-08-2013, 01:00 AM
#192 (permalink)
Cyborg ECU
Originally Posted by euromodder
Yes, but it seems without "fins" like I think Metro is referring to, right? Here is another angle that I don't think is in the thread you linked to... but maybe that open box/wing thing is about the same idea as "fins."
06-08-2013, 01:45 PM
#193 (permalink)
Strakes? Fins? Fences?
We need a Glossary.
Skegs?
06-08-2013, 03:14 PM
#194 (permalink)
solar car
Originally Posted by jime57
I tend to agree with you overall observations. I was just kicking the idea around.
Formula 1 cars have been productively using various diffuser fins for several years now, but I'm not sure that the 150-175 MPH difference in speed makes that comparison relevant.
And, yes I remember seeing that solar car. As I recall, the fins were small and at the very rear.
That might have been the 1987 GM/AeroVironment SunRaycer.
Crosswind stability near the Australian land trains was a prerequisite for racing qualification and that car had already 'flown'.
The 'strakes' added under the tail were a solution which Dr.Alberto Morelli had come up with in 1978 with the CNR 'banana' car.The stabilizing tailfin was placed low,behind the wheels to mitigate a roll-moment,while moving the center-of-pressure well aft,giving it a nice weather-vaning.
06-08-2013, 10:23 PM
#195 (permalink)
My CarBEN EV5 has a three straight diffuser fins, though I have no idea if they wil help or hurt or be meaningless. They provide downforce, I think? I'm hoping that the fins on CarBEN will "straighten out" the air flow so that it swirls less as it exits - maybe?
06-09-2013, 01:33 AM
#196 (permalink)
My understanding would be that the downforce would be affected by the angle of the plate/bottom of the boattail. There is a diagram that indicates the angle is sensitive to the upper rear body shape (which I apparently don't have), i.e., fast/notch/kamm-back, over a range IIRC of 0-10°.
I agree they would reduce turbulence, but I'm curious about how they act in cross-wind conditions. And I think Difflow is onto something with the fan shape.
[post contains much opinion]
06-09-2013, 07:18 AM
#197 (permalink)
Cyborg ECU
Is this the graphic/table you are referring to?
The Following 3 Users Say Thank You to California98Civic For This Useful Post:
06-09-2013, 10:53 AM
#198 (permalink)
I think that is it!  Will someone please explain it to me?
06-09-2013, 12:17 PM
#199 (permalink)
Cyborg ECU
Maybe. Let's see: Cx is another way of noting Cd. The "Y" axis, therefore, is measuring change in Cd (Cx) +/- and the "X" axis is charting different angles for the different body shapes' diffusers. Body shape A and B are shown to have their best diffuser angels at 3 or 4 degrees and the wagon ("C") seems just to suffer.
Reason: three intrusive typos (shakes fist at spelling gods)
06-09-2013, 07:50 PM
#200 (permalink)
Maybe. Let's see: Cx is another way of noting Cd. The "Y" axis, therefore is measuring change in Cd (Cx) +/- and the "X" axis si charting different angles for the different body shape's diffusers. Body shape A and B are shown to have their best diffuser angels at 3 or 4 degrees and the wagon ("C") seems just to suffer.
So, once again, I am doomed?
