10-13-2015, 09:33 AM
Ultimate Fail
How important is a strong ignition spark for FE
My '93 Civic fires right up every single time - sometimes the instant i turn the key.
Most of the time i don't even hear the starter.
However, the car has always had a very weak spark in several ( if not all ) cylinders .
Power seems weak, but this is an old car with a lot of miles. The car I'd also an automatic.
the distributor is new, the wires and plugs as well.
Will i see a big FE Improvement by fixing the issue ?
10-13-2015, 10:03 AM
In Lean Burn Mode
What is the condition of the ground wire on the cylinder head. You can a simple test by taking some jumper cables and making four extra temporary grounds then recheck spark.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
10-13-2015, 01:45 PM
Ultimate Fail
The ground wire is in great shape, and I even added another ( very small ) ground wire.
Old Mech had suggested looking at the grounds some time ago as well.
What puzzles me is that the car fires right up. If there was a grounding problem, or a problem with the distributor, wouldn't there be some problems starting the car ?
10-13-2015, 01:58 PM
How do you know it has a weak spark?
10-13-2015, 06:39 PM
Ultimate Fail
Well it felt pretty weak when i touched it.
....what
( Not being a jerk, just my lame attempt at humor )
I tested the spark plugs and when the car is cranked, there is a pale orange spark. Quite weak.
Ideally, it should be a bright blue.
Commercials for Splitfire type plugs would have you believe that some of your fuel is wasted if you have poor spark.
Is there any truth to that ?
If the fuel ignites, then it is on fire...no matter if the spark was weak or not.... right ?
10-13-2015, 08:13 PM
That's what I'd think, unless it was weak enough to cause an occasional misfire.
I'm not coasting, I'm shifting slowly.
10-13-2015, 08:36 PM
....what
What is the gap set to? You mentioned that you have good grounds but what about a good supply voltage?
10-14-2015, 03:52 AM
Try it with the engine running. You may see a difference!
10-14-2015, 05:24 AM
#9 (permalink)
Ultimate Fail
Gap is set to factory specs. Supply voltage ....hmmm...well I need to test that.
The distributor ( which has a coil built in ) / plugs and wires are all new.
I'll recheck the grounds again this weekend. I just looked it up, and there are a lot more than I thought :
10-14-2015, 05:27 AM
#10 (permalink)
Ultimate Fail
How do you do that ?
