Old 02-03-2009, 11:07 AM   #11 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
I had considered switching to this stuff once the cold weathers gone.
Around here the only FE mobile one I can find is 0W-20 or 0W-30. Are you using those same weights with the standard synth when you switch back to that?
Old 02-03-2009, 12:43 PM   #12 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Has the outside temperature gone up considerably since the new oil? It has here in the last few days, no more -20F weather. Ive noticed a few mpg increase both to work and back, as well as downstate.
I would just want to make sure that all things are near equal first. Since I too would not normally think that oil alone would make that much of a difference.
Winter daily driver, parked most days right now
Summer daily driver
Old 02-03-2009, 01:26 PM   #13 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Chevy (Daewoo) Aveo5 SV
90 day: 30.55 mpg (US)
i am using the 0w-30. and the weather here is always fluctuating. one day it would be below zero, next day in the high fifty's then the day after that in the high sixty's. then back down to freezing.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 02-03-2009, 04:22 PM   #14 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Temperature: there's the big contributor to mpg variations. Unless you can keep that constant, or do a back-to-back controlled test, any changes from the oil will disappear in the statistical noise.
I use Mobil 1, because carefully controlled studies have shown synthetic to be better for mileage. It's also better for the engine. But the difference is small.
Old 02-03-2009, 04:49 PM   #15 (permalink)
ive always used it because i know its better for the engine. if my corvette used it from the factory, then its the right choice for new motors that occasionally get driven hard.
i see it as this, if GM engineers chose to put it in their cars (not all of course) off the line, then its a good choice to use for how i drive my cars.
im trying to change my driving habits for better milage of course.
Old 02-04-2009, 10:45 AM   #16 (permalink)
Grand Prix - '98 Pontiac Grand Prix SE
90 day: 21.53 mpg (US)
Is it actually true that gm put mobil 1 in some cars from the factory? I have read this about my car as well. If it is then were the motors broken in prior to them being installed in the car?
I have always thought that during break in you should use conventional motor oil so that you make sure that the rings set and various other reasons. But if GM puts mobil 1 synthetic into brand new motors then what I dont understand is what the deal is with breakin on conventional.
I know that GM recommends certain oils for different engines but I find it hard to believe that they would want the engine broken in on a synthetic.
Old 02-04-2009, 12:37 PM   #17 (permalink)
wagonman76's Avatar
Team Chevy
Guess I jinxed myself. Woke up to -25F this morning. Took 10 miles for the mpguino display to fully show up.
I have always understood that conventional oil should be used for break-in too, and changed soon.
But as far as what GM recommends for normal use, I wouldn't necessarily consider that to be the best. They want you to use something that is going to get you just past the warranty period.
Summer daily driver
Old 02-04-2009, 07:11 PM   #18 (permalink)
im not quite sure what they used for the break-in period. ive always wondered that. but i know my LT1 in my C4 had mobile one from the start, caddi N*'s use mobile one from the start, and so do the LSx engines. as im sure with a few others.
on my re-man motor i had in my blazer, i used conventional oil for the first 3000 miles, then mobile one after that. did the same with my aveo. first 3000 conventional oil, and after that its been all mobile one. never had any oil leaks or other mechanical related problems.
Old 02-04-2009, 07:38 PM   #19 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
On some GMs I've seen Mobil1 oil filler caps - may have been an option or add on.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 02-04-2009, 07:54 PM   #20 (permalink)
thats probably the recommended oil for that engine. i know my C4 had a Mobile! badge under the hood. i think my oil cap even had it written on it.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
