Old 08-18-2010, 08:39 PM   #1 (permalink)
Meph's Avatar
240Z - '73 Datsun 240Z 240Z
90 day: 34.41 mpg (US)
The 300hp 240z Eco results
Hey guys, update on my 1JZ (Toyota 2.5L turbo) powered Datsun. These are my results after my aero modifications and fuel/ign tuning.
These numbers are rough, speedo was in miles, and reading 7% slow according to needle position vs gps (hopefully the trip counter is pretty accurate to the needle) thanks to differential and transmission changes. The fuel cell was filled up to the "that looks about as full as it was before" point.
After crunching the numbers, 33.5 MPG, 14.1km per liter. Im shocked, I may not have filed up quite to the same level ( I put in 30L from gas cans I filled at pump)
I hope to keep improving this number with tuning, I've since pulled the A/F from 15.3:1 to 15.6:1 and ive noticed my injection times coming down noticeably. All driving was 90km/h and under, no P&G or anything, fair amount of steady crusing, few instances of positive atmosphere too
This is better than my DD, more excuses to drive the 300+HP classic
Old 08-18-2010, 08:57 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Looks great!
I guess you don't have to e-test that puppy, eh? (Thinking about A/F ratios affecting nitrogen oxide output.)
Any more aero mods planned? The most obvious one that comes to my mind is the sculpted headlight covers I've seen on some of these cars.
Old 08-18-2010, 11:11 PM   #3 (permalink)
I've always liked that body style ( at uncle for selling his without telling me)
Old 08-19-2010, 12:00 AM   #4 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Nice car! And thats a nice Grand National in the 2nd pic.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 08-19-2010, 10:20 AM   #5 (permalink)
I take it your running in open loop (no O2 sensor feedback ) to get those lean A/F at cruising speeds (low rpm) ?
Old 08-19-2010, 11:49 AM   #6 (permalink)
Meph's Avatar
hey guys, the wind tunnel tests show a very small cd reduction from headlight buckets, somewhere int he .00x range so i think ill leave it for now, I checked my trip coutner vs googe maps and my trip counter reads 6.75 miles for a 7.5mile actual so an 11% under, using this conversion I was actually above 35MPG!!
I run an aftermarket ECU and wide band sensor, the wide band allows me to set a cross over point of its Narrow Band mimic output. So all i need to do to change the a/f is adjust 1 setting my fuel maps are all around 14.7-15 and the ECU will pull fuel when crusing to get the desired a/f.
Im considering swapping the 3.54 diff for a 3.03 LSD at some point, that will drop revs even lower, a lot of my cursing is at -18 to -20 In-hg, so a little more load and lower RPM maybe help out even more.
Old 08-19-2010, 12:27 PM   #7 (permalink)
Ok, So your able to set a offset voltage to lambda to trick it from normal 14.7 .
If my memory is right you said your using haltech stand alone ECU ?
Old 08-19-2010, 12:28 PM   #8 (permalink)
Congrats. Thats some pretty decent mileage for a huge amount of power (and a beautiful car).
Old 08-19-2010, 12:37 PM   #9 (permalink)
Meph's Avatar
The haltech works off a cross over voltage, 500mv right now. The wide band has an output that mimics narrowband cross over voltage, I have set the wide band to cross over (500mv ) at 15.6:1. The control unit of the wide band will produce a voltage signal mimicking a narrow band but tuned to the a/f ratio you desire. Hook it up to the ecu and your golden
Old 08-19-2010, 12:46 PM   #10 (permalink)
One big advantage If that is based off 240/260Z , there weight was pretty light at around 2400-2600lb and with new motor its probably even lighter as those were long L6's (cast iron blocks ).
My acetone results 5EFE EcoModding Central 24 12-05-2015 11:42 PM
Retro aeromods: Datsun 240Z factory bolt-on "G-nose" good for +5.5% mpg and +5 mph MetroMPG Aerodynamics 25 12-14-2010 11:13 AM
Calibrating the 2010 Power Bar (ECO mode) bwilson4web Instrumentation 1 08-14-2009 11:44 PM
Scratch X results RandomFact314 Off-Topic Tech 14 06-22-2009 10:28 PM
