Old 09-18-2008, 11:42 PM   #681 (permalink)
Red Beast - '82 Honda V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 Honda CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Dodge Neon SXT
90 day: 28.71 mpg (US)
Assembled the Iduino(s) today, hooked up the display and tried to upload the software. The display is not showing anything. (It will show a line of full squares, then cycle off.) I have checked the wiring, connections and the code for the LCD control. I am using the GDM1602k from sparkfun.
The IO light is flashing nicely. so I know that the program is running. Do you need to not have that on?
EDIT:
I removed the LED, still no luck. I have it compiled with debug, and it does print the "OpenGauge MPGuino online" message to the serial port. but still nothing coherent on the screen. Full squares, horizontal lines on the top row. nothing more.
Old 09-19-2008, 12:19 AM   #682 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
First, try turning off debug, and reload it. Then when it comes up hit the middle button (and nothing else) several times and see if the display improves.
Old 09-19-2008, 12:33 AM   #683 (permalink)
No good, it looks like a hardware issue? I had tried to put serial debugging in earlier, it showed me that it was going through the steps. However the display is still FUBAR. (Top row only, solid blocks or single horizontal line.)
Old 09-19-2008, 12:37 AM   #684 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yah, gotta be. If you have an ohmmeter, unplug the guino and check ohmage between all the LCD pins. Except for pins 1,5,16 they should all be at least 10k ohms apart.
Old 09-19-2008, 01:05 AM   #685 (permalink)
Just wondering... how are the pins supposed to be numbered on the display? from the display side or the back side? I just saw the +- pins and assumed they were 1 and 2. I think I found the 1. (The thing is backwards!)
Old 09-19-2008, 01:13 AM   #686 (permalink)
dcb
needs more cowbell
dcb's Avatar
When looking at it from the front, the lcd connectors should be on the upper left. pin 1 should be all the way on the left and pin 16 should be all the way on the right when viewed from the front.
Old 09-19-2008, 01:43 AM   #687 (permalink)
Works well now. (Reversed the pin-in for the display.) I LOVE vacuum de-soldering tools.
Tomorrow: The rest of the parts.
Saturday: Install
Old 09-19-2008, 01:53 AM   #688 (permalink)
dcb
needs more cowbell
dcb's Avatar
Sweet!!
FYI, installing arduino 0012 now, will see how that works
Old 09-19-2008, 01:57 AM   #689 (permalink)
dcb
needs more cowbell
dcb's Avatar
Damn, Binary sketch size: 16772 bytes (of a 14336 byte maximum)
Old 09-19-2008, 02:00 AM   #690 (permalink)
ptsmith24's Avatar
El Camrino - '90 Toyota Camry LE
90 day: 32.47 mpg (US)
I'm not sure how the IDE works in this case, but is the size increase due to different compiler specs or what? Also, do the newer IDEs drop older hardware support (i.e., the one that has been in use here)?
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 09:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 05:23 PM
