07-27-2012, 08:31 PM
#11 (permalink)
NightKnight
It is old tech, but nicely implemented. Would be cool if they could offer the hub motors as part of a kit, where the buyer can buy only the vehicle-specific hub motor and source the rest of the components elsewhere, or buy all the parts from one source.
Not sure if the estimated $3K cost is including everything or it is the hub motor only.
07-28-2012, 01:40 AM
#12 (permalink)
Thanks for sharing the article, but it annoys me at how little information it contained. All of that talking and no mention of how many HP the motors add.
Also, there is zero percent chance that the system can double the mpg of city driving. I actually get slightly better mpg in stop and go gridlocked traffic than steady 70mph freeway travel in my car (which says something about how the horrid gearing).
07-28-2012, 02:18 AM
#13 (permalink)
Pokémoderator
Neil -
Cool. Me love retrofit.
CarloSW2
07-29-2012, 08:56 AM
#14 (permalink)
The video that Darin posted later in this thread mentions 200ft/lbs of torque (per hub motor?).
Electric drivetrains are very efficient in city driving -- no idling and no warm up time and regenerative braking; but most of all they are about 85-90% efficient almost all of the time. And ICE only hits it peak efficiency at a narrow range of RPM, and that is still typically about 30%.
Apparently, the electric motors do not start until you use the ICE to get the car rolling. So, this is a lot like many e-bikes -- it is NOT tied into the accelerator pedal at all, and so it may not do regen, either. Still I think their claim of 2X the unassisted city mileage is plausible.
07-29-2012, 01:53 PM
#15 (permalink)
This looks similar to what the Poulsen hybrid people have been working on.
Poulsen Hybrid
07-29-2012, 02:12 PM
#16 (permalink)
Pokémoderator
basjoos -
Poulsen Hybrid
But (maybe) in a stealthier package than Poulsen?!?!?
CarloSW2
07-29-2012, 02:47 PM
#17 (permalink)
I like this design a lot more then the Poulsen because it's replacing existing parts, like the brake drum, and brake backer plate, with the motor instead of just adding more parts/weight on to the vehicle, why add a 2nd torque arm like the Poulsen has when the brake system is already designed to handle that load, I imagine that a system like this is 100 pounds lighter then a Poulsen hub motor and that lower weight is all unsprung weight, so while I don't agree with hub motors being the best solution this one seems to be a really good retrofit design that could have a low cost, it would be an added cost, but I bet if the brake drum was aluminum instead of cast iron and had a pressed in iron liner like Honda Insight brake drums have that the rotating weight could be kept on par with the stock weight, the the only added weight would be the magnetic coils on the brake backer.
The Following 2 Users Say Thank You to Ryland For This Useful Post:
08-06-2012, 04:47 PM
#18 (permalink)
I've thought about this since the day i read about hub motors for motorcycles!
But, for ease of operation, it would probably be a little easier and convenient (for me) to just convert my Tortion Beam axle to a live RR drive axle and strap on a motor to the input shaft. use the existing frame tortion beam bolt mounts, and make another (2 one on each frame beam) and make 4-link suspension. or Honda CRV rear-end/similar for(independant suspension).. fill the trunk with batteries, and use a lever for consistant power/speed output when in traffic jams, parking lots, city driving. Use ICE (FF) for everything else...
I estimated less than $1,000 for the whole thing, batteries/motor would be the most expensive, most of the controllers/electronics could come from a golf cart or something 36/48v max anyways. Junk yards always have a hidden jem for parts practically free
08-08-2012, 10:17 PM
#19 (permalink)
live, breath, Isuzu-Ds
would it be better to say
mild, plug in, hybrid
since the OE engine is running at all times....?
well i know some of us would shut it off at times.
but would the avereg person shut it down and go with out brake VAC, P\S ect
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED  NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
08-09-2012, 11:02 AM
#20 (permalink)
For us hypermilling fanatics, the only way would be to drive with the engine off no doubt. Were usually familiar with EOC or similar situations...
I dont think the average driver who would drop $3000 for "bolt on" kit would know what would happen if the engine would be off, therefor it would just be left running, in neutral or something (i suppose) when in electric mode. The killer part would be someone who's not familiar shifting from N to D, while at speed and not knowing how there car reacts to those types of behaviors or possibly what to do afterwards when the batteries are drained.<this could certainly throw ppl off of the idea, when they have to take a little time and "learn" something new.
