Old 07-19-2008, 07:39 AM   #131 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Excellent Thread. It's really great to see this from a mechanic. It has helped me out a lot. If you get rid of those lights, and noone else wants them let me know. (:
Old 07-20-2008, 07:12 AM   #132 (permalink)
Will's Avatar
Team Chevy
Question for the mullet: How did you go about dealing with your DRLs?
Old 07-20-2008, 02:10 PM   #133 (permalink)
Steady as she goes
RacerX's Avatar
Shooting Star - '95 geo metro
90 day: 59.91 mpg (US)
HUFFER - '98 Buick Riviera Super Charged
90 day: 30.69 mpg (US)
Kandy, Flake-n-Flames - '96 Buick Riviera Base
90 day: 32.13 mpg (US)
Blue Z - '07 Nissan 350Z coupe
90 day: 34.13 mpg (US)
[QUOTE=Johnny Mullet;45542]Vacuum can vary depending on load. On a smooth road, no wind I run anywhere between 10 and 13hg normally. At idle it's at 19hg.QUOTE]
Thanks Johnny, I'm about the same @ 55, Although @ idle I'm between 16 to 18" (you know how that needle flutters slightly).
How about a 1 Litre Street rod?
Old 07-20-2008, 09:00 PM   #134 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I simply removed the center console.
Slide both seats forward and remove the 2 screws on the sides.
Raise the parking brake lever and get console out of way.
Looked for the wire at the back of the lever.
Loosened one mount bolt and ran wire under it to ground it.
WARNING.........
Doing this action to disable the daytime running lights has the same effect as pulling your parking brake lever up one click. This disables the DRL's, but it also illuminates the "BRAKE" light on the dashboard. You will have no warning if your brake fluid gets low, but most of us "Ecomodders" are always aware of our maintenance and check fluid levels.
Do not attempt to disable your DRL's this way unless you feel confident your car is visible and aware of the brake light issue.
GeoMetroforum.com - got mpg?
Old 07-20-2008, 09:22 PM   #135 (permalink)
Hi-Tech Redneck
Headlight Conversion
This part of my project includes doing away with my crappy headlamp units that are causing poor visibility. I am converting my "Aero Style" molded headlamps with the "Bucket Style" lamps with sealed beams.
"Why replace the aerodynamic lights with the bucket style?"
It's entirely up to the owner. Replacement lamps for my car are well over $100.00 each and I do not plan on dumping that kind of money into the car just yet. I also prefer the older style lamps because they do not get foggy or discolor and are also way cheaper to replace. I may lose some aerodynamics like this, but I would rather have good visibility since the deer around here are cornfed.
This guide will be similar for whatever conversion you decide to do since the steps are all similar.
First off, remove the 2 screws that attach the headlamp unit to the car and carefully pop it out and unplug the connectors..............
Next step is to wire in the plugs since the sealed beam takes a different plug than the aero type...........
I bought 2 new connectors and spliced them in. It was pretty easy for the headlamps since the center terminal goes to the same location on both. Use a test light to figure out which the other 2 wires are. One is "Hi beam" and the other wire is "Low beam".............
Take your lamp and mount and you will see there are 4 mounting holes already in place. The mounting bolts from a car with bucket lights installed will not work since the holes are too big, so I used bolts and nuts................
After they are bolted on, simply plug in the side marker lamp into the replacement unit or housing and then mount them on.
Does this car not look 10 times better now.................
Wait a minute! If the older "Bucket Style" lights come from a car with turn signals mounted in the bumper, how will mine work? Well, if you been following along this thread, you will know that my foglamps I installed behind the grill have a 2 way bulb in them. I simply cut the wires from the turn signal socket and spliced the marker lamps to the dim side and the turn signals on the bright side of the filament. This makes me 100% legal.................
Thanks to RacerX for sending out his unused lamps for me and thanks to all those others who offered theirs
NOTE:
My old lamps are garbage and not worth anything to anyone. I had to cut the mounting tabs on both units to remove them since the bolts were seized. I then used vice grips to remove the bolts since the Phillips parts stripped out.
Replacement Headlamp units = $25.00-shipping (Thanks RacerX!)
H4666 lamp sockets = $13.00
Misc connectors = $3.00
Total cost = $40.00
Total labor time = 2 hours including aim.
Clear visibility = priceless
Old 07-20-2008, 09:39 PM   #136 (permalink)
Will's Avatar
Team Chevy
[QUOTE=Johnny Mullet;45888]I simply removed the center console.
Thanks, Mullet, I appreciate the tip. Yeah I think we all most likely check our fluids often, otherwise our "old" cars wouldn't make it too long
Old 07-20-2008, 10:24 PM   #137 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
I hate composite housings..
I never saw a point in em for anything other than vehicle design/looks..
Have you thought of some H4/9003 style housings so you can replace the bulbs from the backside?
Any thoughts for a cover for the buckets to get the areo back?
Old 07-20-2008, 10:38 PM   #138 (permalink)
Hi-Tech Redneck
bbjsw10 posted a neat lexan cover trick on his thread here............
http://ecomodder.com/forum/showthrea...-xfi-3887.html
I plan on doing something similar in the future.
Old 07-20-2008, 11:10 PM   #139 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Nice job, you should be able to see better now. They have to be brighter.
Honda...the economical, renewable resource.
Old 07-20-2008, 11:25 PM   #140 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Cool hope you like them I had a couple guys asking on mine. I like the old school look better anyway. Good thread by the way. And yes the deer here get large on that corn.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 01:21 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
