Old 07-21-2008, 08:27 AM   #141 (permalink)
Pea Pod - '95 Toyota Tercel
Last 3: 38.61 mpg (US)
Chili Pepper - '06 Honda Accord SE
looks great
wow, mullet, the lights look great!
Old 07-21-2008, 10:13 AM   #142 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I think they are awesome! I even got out last night and drove in the dark to test them out. First thing I had to do is aim them slightly, but now I can see!
Going from this.............
To this...................
is an improvement not only for visibility, but the appearance of the car. I like these "Camaro Style" bucket lights a lot. Sure, I may lose 1 or 2 MPG, but they look great! I never understood why they use lexan plastic for headlamps on a car. My 1995 chevy truck has modern looking lights like the Metro had, but they are made from glass. Glass is the only way to go.
If I remember correctly, JC Whitney used to sell these sealed beam headlamps that turn black when off. I wonder if they still make them and if they have normal brightness?
GeoMetroforum.com - got mpg?
Old 07-21-2008, 05:09 PM   #143 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Hey Johnny make a grill block for that thing it will make up for the difference in headlight easily. That grill opening is huge. Just my .02
Old 07-22-2008, 01:34 AM   #144 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
They were made by Phillips.. Long discontinued and their output was alright, not really an upgrade in my opinion.. these were the H6054's..
these are really old pics..
they basically had a honeycomb matrix shape behind the glass painted black, at certain angles the light output wasn't very good, but straight ahead was fine..
I believe this was the reason they discontinued these..
Old 07-28-2008, 04:15 AM   #145 (permalink)
Hi-Tech Redneck
Frame repair has been completed. The wife had to work midnight shift, so I took advantage of the 8 hours of "me time" to get this done!
I will get the pictures up as soon as I get home. I am happy with the results.
Old 07-28-2008, 07:32 AM   #146 (permalink)
Addicted
bbjsw10's Avatar
Cool pics will be good to see how to fix mine. Your metro is looking good with new lights.
Old 07-28-2008, 08:25 AM   #147 (permalink)
Hi-Tech Redneck
OK, so the reason most Metro/Firefly/Swift models get scrapped is because of the notorious rust issue they have where the lower control arms mount to. I posted pics of how mine was getting pretty bad previously...................
This issue affect all years of this car even though the older models have a slightly different frame, the same "looped" unibody in the front is similar. After time, the frame will rot away to the point where the lower control arm will detach from the car and the wheel will end up kicking out and separating from the car causing loss of control or a crash or a grinding halt. First thing most people do is start grinding away the rust. This is a bad idea in my opinion, because it weakens the surrounding area and if you keep grinding, you will eventually be grinding away to nothing. I learned to simply go beyond the rust area at least 3-4 inches and as long as it's welded correctly, the new repair will hold all the stress and keep the rusted area from flexing and breaking away.
I took a piece of scrap bar stock and cut a piece that would wrap around the front arm.............
I then welded that in place after forming it to fit with a hammer and a vise.............
I then cut another piece that was cut out for the side opening and made sure it contacted the new piece I just welded in....................
This piece was also welded to the rear arm to secure the mount. The important part of welding is to make sure the area is clean where you are welding to and to get a good burn. The weld must penetrate both sections and not look like rabbit turds when you are done. Don't be afraid to burn it in until both contact areas are melting together with the bead you are laying.
I then made a piece for the outside and welded it to the original piece and formed it to go with the contour of the inner fender area and painted it all with flat black paint........
I also repeated the same repair on the passenger side which was not so bad, but still got the same repair with a wrap around piece and both side braces.............
I am totally confident in this repair and should get a few years of service from it and even longer if I maintain the rust as best as possible.
Scrap steel = $0.00
Total cost = $0.00
Labor time = 5-6 hours.
Old 07-28-2008, 10:39 AM   #148 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
looks good to me
Old 07-28-2008, 12:54 PM   #149 (permalink)
Nice looking fix... I'm sure glad I don't have to deal with rust out here in California. I don't know how you guys do it, my hat is off to you, but then again, most people across the US can't understand how I put up with the occational earthquake (thinking back to '89 when the Cypress structure totally collapsed and a peice of the Bay Bridge fell).
You probably already know this Johnny, but check the caster and toe, it likely moved from strenthening the area and from the 'pull' of the welding. As usual, the pictures and descrption of your repairs are awesome!
Old 07-28-2008, 03:55 PM   #150 (permalink)
Hi-Tech Redneck
I am resetting the alignment again even though it did not seem to be changed after the repair.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 01:21 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
