Old 06-16-2015, 02:00 PM   #1 (permalink)
Mustang?
Hello everyone,I picked up an 1989 mustang gt back in november.It is the hatchback and ill post pics later on. I was wondering if you guys could give me any tips to make the old girl do the best on gas. Heres the trick,I'm building a 351w motor for it. High flow aluminum heads,Longtube headers edelbrock cam Ect ect and a 5 speed.(400-500hp) My plans are to lower it and add a vacuum gauge and lighten the car up to a point where it'll be under 3000 lbs. I still want it to look like a mustang!lol no boatails or fender skirts sorry!Im willing to listen about air dams kammbaks and spoilers though.This car will spend 85% of the time on the highway, and I'm spinning at about 2000 rpms at 70mph. Let me know your thoughts,thank you!
Old 06-16-2015, 02:39 PM   #2 (permalink)
Dark Egg - '12 VW Touraeg
Can't help you in the aero but will tell you I spent a lot of time drooling over those late 80s early 90s 5.0 GTs as I graduated high school in 1988 and went in the Navy. My wife and the budget got us a used 5.0 86 Cougar instead, still pretty cool for 1988.
Old 06-16-2015, 03:22 PM   #3 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Electric fan
Underbelly paneling
Underdrive pullies
Bigger amp alternator (140amp minimum)
LED lights everywhere
The LEDS will probably help a lot. The car uses a ton of incandescent lights that suck a lot of power.
The Following User Says Thank You to Baltothewolf For This Useful Post:
mcrews (06-16-2015)
Old 06-16-2015, 04:00 PM   #4 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
How does the bigger alternator help?
Old 06-16-2015, 05:17 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by oldschooleco View Post
Hello.This car will spend 85% of the time on the highway, and I'm spinning at about 2000 rpms at 70mph. Let me know your thoughts,thank you!
There is the key!
85% hiway!
Look at some of my 02Q45 posts, especially on tires.
You need to get a scangauge. Then get out on a freeway and get rpm for 50,55,60,64,70.
and record the rpm(from the scangauge) and mpg for each.
Now you have a base line.
THe sweet spot on the 4.5liter V8 (340hp) in the Q45 was around 1724.
I increased the tire diameter to help get to that. 2000 rpm MIGHT be to high to maximize mpg.
since you are doing so much hiway drivng, losing a little of the line wont matter.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-16-2015, 05:21 PM   #6 (permalink)
Because the under drive pulleys will spin the alternator slower? i think?Im skeptical of them for that reason and they also spin the water pump slower…Which will make a 450hp V8 heat up rather quickly in traffic.Everything else i totally agree with.Thank you
Old 06-16-2015, 05:55 PM   #7 (permalink)
Furry Furfag
Bigger alternator means it will run at a lower cycle rate which means it doesn't pull as much from the engine. Testing will be needed for Underdrive pullies, but if you go a high flow water pump and a good radiator (like you should) then it shouldn't be a problem. I gained 1mpg when I upped my alternator to a 140amp from the pathetic 80A that's stock on my '91. Not to mention my lights don't dim at night anymore.
Also, I would run like 12-14° timing if possible, I gained like 2mpg when I bumped my timing to 14°. Cruising was way easier as was my acceleration. Idk with a 351 if you will be able to run that high of timing without knocking. Again, testing will be needed.
Still, I think stock you can get 19-21 on the freeway, if you do some other mods you can probably get 25ish
How high of compression are you running?
Old 06-16-2015, 06:26 PM   #8 (permalink)
MUSTANG aero
You might peek at the MUSTANG SVO.
It was aero optimized a bit with a patented bi-wing rear spoiler.The wheels are lower drag.
A NASCAR-type nose would improve drag and lift.
Old 06-16-2015, 08:15 PM   #9 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
http://www.streetlegaltv.com/news/de...speed-mustang/
cdn.streetlegaltv.com/image/2014/03/photo-24-Custom1.jpg
cdn.streetlegaltv.com/image/2014/03/IMG_1942-Custom.jpg
http://www.speednik.com/files/2014/0...om-640x426.jpg
cdn.streetlegaltv.com/image/2014/03/IMG_1918-Custom.jpg
The Following User Says Thank You to dirtydave For This Useful Post:
Sven7 (06-22-2015)
Old 06-16-2015, 08:31 PM   #10 (permalink)
darcane's Avatar
That's going to be a challenge because...
<snip>
'89 Mustang with a 351W? There's no OBDII in 1989 and most likely the engine swap means it's carbureted now too.
Sounds to me like the OP is building a race car with outdated technology but would like modern fuel economy. Aero and gearing will help some, but mostly this is putting lipstick on a pig. Keep the car a "5.0" with a Coyote motor and a 6-speed, and you can probably hit the same power with significantly better mpg.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
