Old 09-02-2008, 09:42 AM   #1 (permalink)
F150 - '97 Ford F150 Lariat
Taurus - '02 Ford Taurus SE
the 73 - '73 Ford Thunderbird
the race car - '95 Ford Thunderbird LX
The Brick - '98 Buick LeSabre Limited
My 95 Thunderbird.
No, it is not an eco car per say....but it is one of my other cars.
Some on here were asking to see some pics of it and another car I have...so, here it is.
Well, it is a 1995 Thunderbird.
It used to be my daily driver, it had a 4.6L with a 75 dry shot of nitrous.
Back then at its current weight of 3,940 lbs, it ran a best of 14.15 @96 mph, while cutting 1.99 60's on street tires.
Here are a couple pics of before....
Well, after running nitrous to long untuned, it got the best of my engine.
So, out came the 4.6 and in went a 351W and a C6 tranny.
Install was pretty fun. Since no one makes aftermarket stuff for birds, I had to custom make a few things to get stuff to fit right.
First off, to get the engine to fit, I had to cut the rear of the k-member to get the 7 quart moroso pan to fit.
Next, to get any kind of header to fit, I had to make my own steering shaft...
Had to bend my longtubes a bit to make em fit around the C6 tranny...
Still use the OEM in-tank fuel pump for now....but added a low pressure return style FPR...
throttle cable and bracket...
water pump and pulley setup..
New aluminum radiator and 2- 14 inch electric fans...
Old 09-02-2008, 09:46 AM   #2 (permalink)
And here is a whole engine shot...
Interior is pretty much gutted...
sheet aluminum door panels..
Exterior is basically stock, I run factory spare wheels up fromt with 165R 15's on them. and Out back are stock t-bird fan blades with 26x8.5x15 slicks.
track pics..
I'm sure I've left something out, but here is a rundown of my mods...
Still running stock heads, cam, and intake 351W from an 85 F150.
Edelbrock 600cfm Carb.
Mallory Unilte Dizzy
MSD TFI coil.
Accel wires.
1 5/8 Longtubes
2 1/2" exhuast(about 12 inches) into dumped Edelbrock mufflers.
2" carb spacer
Electric water pump
4:10 track lock rear
MT 26x8.5x15" slicks.
More weight removal....car is now down to 2,960 lbs.
suspension....up front is QA1 coilovers, speacially made for the car(which means $$$$$$). They are 12 way adjustable 90/10 with 325 lb springs.
out back are OEM springs with 2 coils cut on each spring.
also, still run the stock IRS.
It ran a best of 13.85 @96.42 mph w/ a best 60' @ 1.88, and best 1/8 was 8.79 @ 78.33 mph.
time slips....
Old 09-03-2008, 03:12 AM   #3 (permalink)
newbie here to learn
Hot Rod toyota - '87 Toyota pick-up 2wd
AWESOME pics tbird! you really do pay attention to detail! That steering job you did looked pretty impressive.
Old 09-03-2008, 10:46 AM   #4 (permalink)
Thanks man, it means a lot.
Old 09-03-2008, 10:47 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Nice car! I think you did a very nice job on it!
GeoMetroforum.com - got mpg?
Old 09-21-2008, 10:00 PM   #6 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
very nice, the best thing ya did was ditch that computer controlled smog equipment choked 5.0
Old 09-23-2008, 09:55 AM   #7 (permalink)
actually, it had the 4.6L in it.
Old 09-23-2008, 02:09 PM   #8 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
I *personally* would love to swap a 32v motor and 6 speed into a '12th' gen bird. Im just not an old pushrod/carb guy I guess.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 09-23-2008, 02:22 PM   #9 (permalink)
that can be done easily.....you over on tccoa?
Old 09-23-2008, 02:33 PM   #10 (permalink)
bhazard's Avatar
No but yeah I have seen a couple.
Best MPG - 36.8
95 Civic EX - Too much power abshnasko EcoModding Central 16 03-01-2011 11:19 AM
Aeromoding my truck ('95 Chevy S10 pickup) bennelson Aerodynamics 42 12-17-2010 06:28 PM
My sister's 95 Celica and me Daox Success Stories 2 08-16-2008 02:27 PM
Boosting Fuel Economy of '95 Chevy Pickup Spiffytexan EcoModding Central 12 07-01-2008 11:47 AM
95 metro parts combatable with 94? Pillzilla DIY / How-to 2 05-05-2008 10:59 AM
