Old 07-23-2008, 09:11 PM   #1 (permalink)
Smile have some questions about a vx or hx swap
i have a few questions regarding a vx or hx swap on a standard dx,lx,ex civic.
i have located a few civics year range of 96-99 near me and i am considering either swaping in an hx or possibily a vx transmission. would a transmission swap be something that a typical transmission shop would be able to perform?, or would a full motor+transmission be easier to have someone perform? or possibly is a swap of this sort something that you would have to have a specialist with experience in this area perform?
Old 07-24-2008, 01:07 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You could easily do it yourself, I should think, but the transmission shouldn't add any difficulty, it's the same housing just different guts.
Good luck!
Old 07-24-2008, 02:46 PM   #3 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
a tranny swap should be a piece of cake for a shop. Most Honda's by far the easiest cars to work on. I'm swapping my tranny from a ex(short gear) to a vx tranny and one of my friends said he would do it for $50, worth it for me to not get dirty, lol.
And If you want to really push the mpg envelope it would probably be cheaper to just start out with a Hx since you are looking for a 96+ year civic.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-24-2008, 11:54 PM   #4 (permalink)
i appreciate the replies,
as far as expense i am currently near the atlanta area so i have a few 96+ civics located that would be less expensive with an hx transmission swap figured in. do you have any experience as what could be expected in terms of mpg gain from the hx transmission in an dx/lx/ex? i gathered @ a 4-6mpg increase? they are cars that would need a transmission anyway so i thought i would research the pros and cons of the hx transmission being swapped in, i've also gathered that the hx automatic transmission is very prone to failure os i suppose i will go with the manual, i am not certain about the vx however.
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Got a few swap questions (help vxers?) SVOboy EcoModding Central 8 06-08-2008 10:15 PM
VX into 93 Civic Si swap? stiles DIY / How-to 4 06-04-2008 03:48 PM
VX swap questions reformed EcoModding Central 7 03-05-2008 08:24 AM
HX powerplant swap... worth it? reformed EcoModding Central 6 02-03-2008 04:00 PM
