Old 04-26-2009, 10:24 PM   #11 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
I used a power buffer and a $2 can of car polishing compound on my GF's car headlights. Cleared them up quick. No side affects so far, but they are slowly starting to come back.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 04-26-2009, 10:32 PM   #12 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
As I was washing the car today, I noticed the headlight lenses are starting to get just a bit cloudy (automotive cataracts? ) I'd like to polish them up, but I'm wondering if there isn't something to apply to them after they are all polished up and clear, to keep them that way? Or do you just have to keep polishing them occasionally? I suppose it wouldn't be too bad, if you can keep up with it.
-Terry
Old 04-27-2009, 08:55 AM   #13 (permalink)
Driving the TurboWeasel
Polishing occasionally. There's talk of clearcoating after polishing well, but I don't know how that works long-term.
2012 Chevrolet Cruze Eco 6MT
Old 04-27-2009, 09:38 AM   #14 (permalink)
I've used metal polish and plastic polish with a cloth to buff it and that worked excellent. Once they turn yellow, the UV protectant in the plastic is gone so they will turn yellow again rather quickly. I've heard the UV-block clear coat extends that time indefinitely it it's reapplied every 6 months or so. I tried it, but swapped out the headlights after only a few months (they still looked good, though), so I can't vouch for the effectiveness long term.
Old 04-27-2009, 10:15 AM   #15 (permalink)
I would be hesitant to use whitening tooth paste.
Its actually got some nasty side effects if you aren't careful. For example if you leave the stuff on your skin for extended periods(not residue but if you rubbed it against your arm on accident in the bathroom) it will burn your skin.
The whitening compound specifically if you talk to your dentist or your dermatologist they will tell you not to leave it on your skin. I discovered this combating acne and then had to go to the doctor again to do something about the skin.
I would bet paste with "refreshing crystals" would be your best bet as that stuff feels like sandpaper if you rub it off.
Old 04-27-2009, 11:25 AM   #16 (permalink)
Kayak hauler - '05 Mitsubishi Lancer ES
90 day: 33.88 mpg (US)
Have you tried putting RainX on the inside and outside of the lens cover? Not sure how well it works on plastic but it will help keep dirt from sticking to the rear window.
Old 05-10-2009, 08:41 PM   #17 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
I did my girl friends head lights and they cam out pretty awesome (the one on right I forgot to take a picture before putting toothpaste on, so I took the pic with the toothpaste)
Name:	Megans Left Light Results small.jpg
ID:	3447   Click image for larger version
Name:	Megans Right Light Results small.jpg
Old 05-10-2009, 08:43 PM   #18 (permalink)
UfoTofU's Avatar
UfoTofU - '91 Honda CRX DX
Last 3: 28.36 mpg (US)
That looks great
Old 05-10-2009, 09:02 PM   #19 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Wow. Mine didn't even half way clean that well. Actually, I'd hardly say it did anything.
What are you rubbing it with?
Old 05-10-2009, 10:14 PM   #20 (permalink)
90 day: 34 mpg (US)
My hand and wiping it off with a rag
diy, fix, headlights, restoration, success
Lexan headlight cover how-to bbjsw10 DIY / How-to 34 10-27-2019 08:04 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
EMAIL friends results to PROVE hypermiling works mush3gan Hypermiling / EcoDriver's Ed 8 07-23-2008 03:24 PM
