Old 12-04-2009, 12:45 AM   #61 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I think 30:1 is way outside the increased NOx range, so that should be the ticket, if that's what you're going for.
Could you provide some information or a link on your combustion chamber mods?
I know you said you'd provide engine pics as the disassembly went on, how's that going?
Old 12-04-2009, 12:58 AM   #62 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Nerys View Post
whats a lean burn prechamber?
There are a few different lean burn prechambers out there.
My design is built into the heads combustion chamber. Its a secondary chamber that runs at a lower A/F ratio, around 14:1, while the original combustion chamber is lean out to around 25:1 A/F ratio.
The prechamber is creating a nice flame kernel propagating downward to ignite the rest of the lean 25:1 air fuel in the original combustion chamber.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-04-2009, 01:06 AM   #63 (permalink)
Honda CVCC -
Similar?
Old 12-04-2009, 01:07 AM   #64 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
That's the ticket I'm going after. It will pass emission as of now but I'm cheating.
I simple put my stock fuel and ignition map in (named pass emissions map)LOL
Pass the sniff test then reinstall the lean burn map.
Eventually I will show some pics. I just want to make sure everything is working before I show how crazy this is and have some else melt down their engine and blame me. LOL
The tear down went great and every thing looks good. No signs of detonation or over heating the internals.
The Following User Says Thank You to pgfpro For This Useful Post:
Christ (12-04-2009)
Old 12-04-2009, 01:09 AM   #65 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Honda CVCC -
Similar?
That would be the most similar.
Old 12-04-2009, 01:12 AM   #66 (permalink)
Waiting for those pics, then. Don't blame you, though... I'm sure someone would say something to the effect that they don't want anyone to try it because it could hurt something, even though testing requires sacrifice... good call!
Old 12-04-2009, 01:22 AM   #67 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I have to give some major credit to naturalextraction
I hit a major wall and could not get over 19:1 A/F when the ambient temps were colder with the Fall season setting in. I had some surge issues at these temps and couldn't fix it. Then he mention to increase the intake temps and it was a instant fix.
All I had to do was by pass the inter-cooler.
Sometime the answer is so simple.
I Love this site!!!! Lots of good people.
Old 11-09-2010, 10:14 PM   #68 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Is this project still alive ?
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Scion xA aero mods NeilBlanchard Aerodynamics 521 04-20-2015 10:34 PM
Red Jelly Bean Aero Mods. minic6 Aerodynamics 13 10-24-2008 11:01 PM
Aero mods for our coupes?? swoody Aerodynamics 14 09-05-2008 02:07 AM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 06:44 PM
