12-03-2009, 09:46 PM
#51 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
The delsol part of the title kinda looks like it could be deIsol... I guess someone could confuse it.
12-03-2009, 09:53 PM
#52 (permalink)
In Lean Burn Mode
Thanks, much appreciated!!!
I will get the dimensions Sunday. Its really cold right now and I'm having a hard time going out and working on it. Plus my wifes cars thermostat went out and I have to fix it first.
Pressure Gradient Force
The Positive Side of the Number Line
12-03-2009, 09:56 PM
#53 (permalink)
You want I should just take some arbitrary measurements, like the width bottom and top, and OAL from top to bottom, etc?
12-03-2009, 11:15 PM
#54 (permalink)
Grrr :-)
I could SWEAR you said it was diesel. (or maybe I saw the 1.6 and assumed it was a diesel) WOW your getting 74 freaking mpg on a gasser and a 1.6 no less! Insanely impressive.
ahhh Figured it out. I started from page one and the first line I read was this
My turbo-delsol- aero mods
my brain fart glossed over turbo-desol and read turbo diesel :-) my bad.
12-04-2009, 12:14 AM
#55 (permalink)
In Lean Burn Mode
LOL Thanks Man!!!
I contribute the great mileage to my home built lean burn prechamber.
This is something I have been developing for the last ten years.
Its not perfect either. It still has one draw back. Its producing higher then allowed NOx levels. I have a few ideas on how to fix this but it will have to wait until next year.
12-04-2009, 12:15 AM
#56 (permalink)
Are you running hot, or just lean?
Were there any other direct measurements you can think of that you'd need off that hatch?
12-04-2009, 12:22 AM
#57 (permalink)
Grrr :-)
whats a lean burn prechamber?
12-04-2009, 12:24 AM
#58 (permalink)
Not to answer for OP, but if I understand correctly, it's basically the same type of prechamber that IDI diesel engines use to pre-combust the gasses in a rich environment, forcing the initial pressure pulse to ignite the rest of the very lean mixture, preventing pre-ignition *detonation* from occurring and damaging the cylinders.
Please, if I'm not correct, correct me. I never really got a good description on it.
#59 (permalink)
Old school diesels used it to help ignition and reduce noise and other ill effects of a harsh combustion shock wave. Might be more better info on it if you google it.
12-04-2009, 12:43 AM
#60 (permalink)
In Lean Burn Mode
I running both. Intake temps when in lean burn mode anywhere from 140*F to 190*F
Lean burn mode from 19:1 A/F ratio high load (acceleration to climbing hills) to 25:1 steady state cruising speed. I'm hoping to get it up to 30:1 in SSCS mode.
I think the measurements you said earlier in the post will get what I need?
The Following User Says Thank You to pgfpro For This Useful Post:
