10-22-2009, 01:10 PM
#51 (permalink)
I think they did a pretty good job with the test. They even kept the clay inside the car for the final test.
I also was amazed that they made it though a whole episode without blowing anything up.
10-22-2009, 02:56 PM
#52 (permalink)
Grasshopper
I was a little disappointed with the results. A father test run would have revealed more. But hey gas is expensive. And they have to save money for all the ballistics gel they use.
And I think Grant "blowing up" kinda counts
10-22-2009, 04:11 PM
#53 (permalink)
FWIW I worked with Mythbusters for their "will subwoofers cause an SKS to slamfire" episode (the talkative guy from MTX, Paul, used to be my boss - now I have his job and he's doing product development) - I can say from direct experience that they do not fudge results, make things up, or do any tricks to skew the outcome in any particular direction. The results you see on TV are the results of the testing which they do carry out in earnest.
Work From Home mod has saved more fuel than everything else put together.
The Following 2 Users Say Thank You to shovel For This Useful Post:
10-22-2009, 04:48 PM
#54 (permalink)
In Lean Burn Mode
They did a very poor test on this one and should of known better.
The amount of fuel that would be measured roughly would have been .06 lbs total and a difference of .0066lbs or 3 grams of fuel.
They needed to travel a longer distance.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
10-22-2009, 04:58 PM
#55 (permalink)
Everyone's a critic
10-22-2009, 05:46 PM
#56 (permalink)
If there was a small effect on the small scale car, it follows that there would be a big effect on a bigger car.
The simplest assumptions often seem the most clever ones. They are also usually wrong.
You're thinking: "How can 800 pounds of clay added to the outside of the car not change its fuel economy?" But you're thinking about it wrong. See, we're not measuring the overall real world fuel efficiency of this car. We're measuring it at very precise conditions, i.e. at 65 mph for exactly one mile. Now I grant you, but the clay on the car, it probably burnt more fuel to get up to that speed, but that doesn't concern us. We expected to see no change with the clay on, and the data bore that out.
Tire pressure didn't change, hence more rolling resistance. The car is definitely sitting lower with 800 pounds on it, hence less aero drag. But then again it's got a slightly larger frontal area. It's kind of surprising all of that evens out, but anyway.
I can see it now, all the NASCARs are gonna be looking like this. What do you think?
I think there's a reason land speed record cars do not look like this.
They like A-B only testing do they. Even the beer-liquor test was done that way.
This is also something interesting...
10-22-2009, 05:50 PM
#57 (permalink)
Originally Posted by tasdrouille
Anyone who knows a thing or two about aerodynamics will tell you dimples do not scale up to work on a car. An 11% increase in FE at 65 mph is more or less between 15 to 20% reduction in drag, that's way too much for not having been universally accepted in the past.
Possibly, but judging by comments on the internet and even here, it sounds like most people wouldn't want a car that looked like that. Just like the people who think a grille block, mirror delete, etc, looks ugly, despite the real-world gains.
However I do agree with the others that there is a better solution than 850 pounds of clay. I'd drive a dimpled car any day. Kudos to the Mythbusters for testing something useful in a controlled way. Maybe we should get on their message board and suggest they do a full-tank test, or something to that effect for more/better results?
10-22-2009, 06:02 PM
#58 (permalink)
I think we should write in.
The Following User Says Thank You to MadisonMPG For This Useful Post:
10-22-2009, 06:09 PM
#59 (permalink)
A longer distance certainly would have helped....
But check your math.
IIRC, they made five trips of one mile, but they measured after each and averaged them.
At 26mpg I get:
1 mile at 26mpg = .0385 gallons.
.0385 gallons x 6.25lbs/gal = 0.241 lbs of gasoline.
.241lbs = 3.86oz or 109g
At 29mpg I get:
1 mile at 29mpg = .0345 gallons.
.0345 gallons x 6.25lbs/gal = 0.216 lbs of gasoline.
.216lbs = 3.46oz or 98g
That's certainly a measureable difference.
The Following User Says Thank You to darcane For This Useful Post:
10-22-2009, 08:55 PM
#60 (permalink)
In Lean Burn Mode
At 26mpg I get:
At 29mpg I get:
Your right I forgot I still had my engine settings set on a four cylinder in my spreadsheet and forgot that my numbers are fuel flow per injector.
So my figures came out to be 106grams and 96 grams with a difference of 12grams based on a specific gravity of 0.728, in which is measurable but still way to small of an amount to conclude a accurate test.
I still need to see the show. Did they do a ABA test? Because I know for fact that the fuel injection system will hold more or less fuel then 12 grams based on fuel temps alone.
