Old 05-26-2011, 01:37 AM   #11 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
You wouldn't have to.
Each would control an axle. You would need to be able to send throttle information to each.
One way to do it would be to leave the gas engine system controlled by accelerator and then have a separate throttle for the EV system. For example, a hand control, trigger on the stick-shift, etc.
The EMIS system uses control box that plugs into the OBD2. Signal from the OBD2 is translated into a throttle control signal to the EV controller.
The vehicle wouldn't care if it were pushed by a motor on the rear axle, or pulled by a gas engine on the front, or both at the same time.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 05-26-2011, 08:22 PM   #12 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Originally Posted by bennelson View Post
I always thought a Geo Tracker - 4 wheel drive, manual transmission would make an excellent platform for an experimental gas / electric hybrid.
Each system would independently power each axel. It would be a "through the ground" hybrid.
Put the electric system on the rear axel though - doing burn-outs without revving an engine always takes people by surprise!
I'm pretty sure a Tracker is RWD so it would be a lot easier to make the front electric. Just loose the transfer case and get a driveshaft for a 2WD Tracker. I think there are some small SUV's though that are FWD primarily if you wnted to make the thing do burnouts with the electric motor.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Old 05-30-2011, 10:45 AM   #13 (permalink)
an idea that I have been considering, is a synergy drive type system where the clutch of a standard transmission is replaced with a planetary gear set. The ICE would then be set to a constant RPM that would be its optimum efficiency, all that would require is that the correct resistor replace the accelerator position sensor. Then the motor would determine speed without need to talk to the ice.
Old 06-02-2011, 09:20 PM   #14 (permalink)
ecowannabe
Skeeter - '89 Ford Escort LX
Could you think of a way that I could power that front driveshaft by the electric motor at some moments but switch to the ICE when real 4x4 is needed?
