Go Back   EcoModder Forum > Forum News & Feedback
LinkBack Thread Tools
Old 10-02-2011, 10:41 AM   #271 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
What's wrong with more aero AND more hypermiling? I'm going to try to stay above 50 for the winter, but next summer should( hopefully) see a VW in the top 10.
Looks like 90 day attrition is happening to a few teams and Team 'Yoda has fallen behind VW again. We need to get some of the high mileage diesels back.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 10-02-2011, 11:07 AM   #272 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Absolutley nothing wrong with aero and hypermileing. It's just that with better aero I can return to driving on major highways and not take the additional FE hit for higher speeds. Most of the hypermiling will remain because they are now learned habits that won't go away. I haven't used my cruise control in months and better aero would allow the return of cruise control to the fold.
Old 10-02-2011, 12:40 PM   #273 (permalink)
Diesel
Know what you mean about "learned habits." I find myself looking for the engine kill switch when using our service truck at work( not a good idea in a 20,000gvw truck).
Boat tail project
Old 10-03-2011, 09:33 PM   #274 (permalink)
Motorcycle
Motorcycle
Our sevice truck is a gas job with an automatic, that is very close to its' GVW wt limit. Some of the things that can be done is coast in neutral, and turn engine off at railway crossings when lights are flashing, and when behind three or more cars at a intersection red light...
Old 10-04-2011, 07:48 AM   #275 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
The daily commuting Mazda6 2.2 diesel is now added..
unfortunately, the Driver (my female colleague) is still enjoying the power..
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 10-04-2011, 09:59 AM   #276 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Did you happen to note your average speed for the tank? Context is good. Not minimizing your achievement.
My best 104 mpg fill-up in the Firefly was at ~20 mph average, per the SG (which is not a "rolling average" speed - it includes time stopped, up to 5 minutes).
Originally Posted by PaleMelanesian View Post
It's my usual ~25 mph average, by the scangauge. That means 30-35 rolling average. Same as I've been doing on this commute for years. I've got 35, 45 and 50 mph speed limits, which are ideal for good mileage. I do a 25-40 P&G cycle most of the time, adjusting a little higher or lower at certain points. (like 5 mph past the neighbors as I approach home. )
Thanks for the added info. (I always imagine noobs reading the eye-popping numbers - good to give background on what's needed to achieve them.)
I recently had reason to drive my route at higher speeds. I had to meet a contractor at the house. Driving style this time:
- my usual moderate acceleration, about the same as general traffic
- top speed at the posted limit, p&g down to 5 mph below where the road is clear
- minimum braking, carry no extra speed into stops. This means some long glides, one is a mile long before the stop.
My Scangauge-reported average speed? 30 mph, about 5 mph higher than my normal. I also lost about 10 mpg. I'll gladly trade 2 minutes for that.
Old 10-04-2011, 10:44 AM   #277 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
This is a good explanation of much of my driving too. I go faster than you but I have largely emulated your driving tactics and strategies and I own nearly the same car, though I have modified mine quite a lot, as you know. My UG won't give me ave mph because the EOC routine messes up the data (I get numbers like 87 ave mph sometimes). Much of the difference between our 90 day averages (88 mpg and 61 mpg) might be explained by speeds? My goals are to hit, exceed, or stay within 5 mph of the posted speed limits, which are generally 50 on the main roads, 25/35/45 on the neighborhood streets, and of course 65 on the freeway. I like to imagine that what I am doing can be scaled-up to the MT parts of the US auto fleet without radical changes to roads or speed limits.
Old 10-05-2011, 09:15 AM   #278 (permalink)
Hypermiler
Wagons
Well, it was suboptimal because I only let the glides go down 5 mph. A 15 mph spread is better if the conditions allow. I have specifically chosen my route to allow such speed variations.
I'm sure you know that 65 is too fast for good numbers. Your aero mods help, but the gearing is still working against you. You're running 2600 rpm at that speed. I aim to keep it below 2100 at the peak of my pulses, and even lower most of the time.
Old 10-05-2011, 10:12 AM   #279 (permalink)
90 day: 51.82 mpg (US)
Do you have a kill switch, or are you using the key?
Keying off the ignition screws up the ScanGauge readings in my Firefly - but adding a kill switch fixed the problem.
http://ecomodder.com/forum/showthrea...gine-4370.html
Old 10-05-2011, 11:24 AM   #280 (permalink)
Cyborg ECU
I installed an injector kill switch with a friend. It cuts-off the ground. When I time it right, the UG does not even go black temporarily. But it has always been the case that in the "run" position, with the injectors off, the speed average starts climbing steadily, almost as if it is calculating distance traveled in some unknown metric.
EcoModder is now on Twitter! SVOboy EcoModder Blog Discussion 4 06-09-2015 04:04 AM
Electrathon Team - Watertown, Wisconsin bennelson Fossil Fuel Free 16 06-01-2015 12:22 PM
Game's on! Ultimate Ecomodder Fuel Economy Challenge MetroMPG Events & Meet-ups 297 06-15-2014 07:21 AM
Official EcoModder ScanGauge II group buy info MetroMPG Instrumentation 71 03-30-2010 07:48 PM
EcoModder Wins Best Non-Hybrid in GreenDriveExpo MPG Challenge SVOboy EcoModder Blog Discussion 3 07-22-2009 10:40 PM
