Old 04-10-2012, 09:45 PM   #21 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
Thanks for the input. Yes the poly is going to be real late in the game. First will be a tune up followed by a grill block and airdam. Tomorrow I am getting plates for it so I can drive it,haha
Old 04-10-2012, 10:07 PM   #22 (permalink)
Originally Posted by Sporty Modder View Post
From what I estimate about 75 lbs. Dont know how much mpg but less weight means less power to move.
75 lbs from 3 toyota windows?!?
Old 04-10-2012, 10:23 PM   #23 (permalink)
Sports Cars
Pickups
Have you seen the size of the back window, probably weighs close to 75 lbs by itself. Poly weighs about .25 / 1 per cu ft. when I do it I will post actual weights.
Old 04-11-2012, 07:32 PM   #24 (permalink)
Sports Cars
Pickups
Changed the plugs today and replaced some vacum lines car started right away. Looking at tmy haynes I realized all the vac lines go to the wrong areas. Tomorrow I have to replace the upper radiator hose and straighten out the vac lines and clean the air filter.
What I am working on.
Old 04-11-2012, 07:40 PM   #25 (permalink)
Sports Cars
Pickups
The hole on the left top side of the pic is where the washer fluid reservoir used to be. It has a hole I could stick 4 fingers into.
The vac lines are too soft to be reliable. Fortunately vac hose is only $3.19 for 3 ft.
Old 04-11-2012, 11:29 PM   #26 (permalink)
Sports Cars
Pickups
Well frank you were right. Doing reasearch on google I found 1/8" window glass weighs 1.7 lbs per sq ft. poly weighs .75 lbs per sq ft.
Rough measurement 12 sq ft back window 1.5 sq ft per side window total 15 sq ft. total glass weight 25.5 lbs total poly weight 11.25. Weight savings 14.25 lbs. Def going to be a long way off.
Old 04-11-2012, 11:34 PM   #27 (permalink)
That's more like it.
Old 04-12-2012, 07:32 PM   #28 (permalink)
Sports Cars
Pickups
Well its official! Got new tires today, registered yesterday and replaced the leaking radiator hose. I am going to be driving it now in the search of a job, instead of the suburban. Woooo hooo!!
Old 04-12-2012, 08:46 PM   #29 (permalink)
90 day: 49.35 mpg (US)
Congrats. Fill 'er up on day 1 so you can start getting your "baseline" fuel economy figured out.
Old 04-12-2012, 09:12 PM   #30 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I have 5 posts now lets see about some pics.
Nice looking ride!
I wish you success in getting it running really nice and increasing the mpg. Looks like a pretty aerodynamic body shape.
Coast long and prosper.
