Old 08-01-2012, 08:42 AM   #11 (permalink)
My brothers Prius' mileage jumped by an estimated 5 MPG when he bought new Ecopia Bridgestones, but the tires he replaced were cheap junk the dealer had installed when he bought the car used a while back.
It's not scientific or ABA but I think I will try them on my Fiesta when I wear out the original Kuhmos.
regards
Mech
Old 08-01-2012, 10:25 AM   #12 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
The Ecopia EP100 summer tire was tested and shown to provide a 3+mpg improvement over other LRR tires and a nearly 4mpg improvement over a non-LRR economy tire. Compared to a performance tire the improvement would be even higher. Unfortunately I have not seen any tests on the all-season variant the Ecopia EP422 but it should be nearly as good.
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
Old 08-01-2012, 12:57 PM   #13 (permalink)
kYLEMtnCRUZr's Avatar
OHRALLY - '99 Subaru Impreza 2.5RS Coupe
90 day: 34.06 mpg (US)
COROLLYPOLY - '02 Toyota Corolla LE
90 day: 46.97 mpg (US)
The Ecopia 100 only shows 3 15" and 17" sizes on tirerack. The 400 series has a lot of sizes to offer. I overlooked Bridgestone since I assumed they were made in Japan, which I try not to support shipping stuff overseas if I can help it, but TR says "US" so I might try them.
Any objections to 195 55 16 (19 lbs and 24.5 dia) over 205 60 16 (21 lbs and 24.9 dia) saving 2 lbs but slightly shortening my top speed?
Thanks!
Old 08-01-2012, 04:34 PM   #14 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
That'll actually raise your top speed. 195/55/16 has an outer diameter of 24.4", making 825 revs per mile. 205/60/16 is 25.7", making 785 revs per mile. When your speedo reads 60 mph, you are actually travelling 63.0 mph.
Transmission type Efficiency
Old 08-01-2012, 08:32 PM   #15 (permalink)
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
when is that new tire rack test on LRR's coming out?
Old 08-01-2012, 09:07 PM   #16 (permalink)
F8L
F8L's Avatar
It's out but the didn't get any mpg numbers...
Testing Passenger and Touring All-Season Tires
Interestingly, the Ascend didn't do as well as expected. I thought the wet traction was fine but I didn't have the luxury of comparing it with other tires back to back. Still pretty lame they didn't get any mpg figures.
Old 08-02-2012, 01:23 AM   #17 (permalink)
Yeah, the last TR LLR test is 2 years old!
But all speedo numbers aside, it will lower my RPMs at 60mph which will produce slightly better MPG right? Which is why racers use 13/14's for better accel with a shorter ceiling on top speed.
Old 08-02-2012, 06:30 AM   #18 (permalink)
F8L
F8L's Avatar
A shorter tire will raise your RPM at 60mph and produce lower mpg in general.
Old 08-02-2012, 07:10 AM   #19 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
It will RAISE your RPMs to use smaller wheels/tires. The reason race cars use smaller wheel/tire combos is because it lowers the weight the engine has to move instantaneously, meaning better acceleration. Coupled with engines that regularly go above 10k rpm's, they don't have to worry about running out of revs and they're definitely not worried about MPGs.
Taller tires weigh more but are balanced out by responsible eco driving, and give you fewer RPMs per revolution of the tire, allowing you to run your engine at lower revs to save fuel.
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
Old 08-02-2012, 07:40 PM   #20 (permalink)
What is the point in testing LRR tires and not displaying their MPG or fuel saving abilities... That is like testing which airplane floats in water the best...
The Following 2 Users Say Thank You to turbovr41991 For This Useful Post:
brucepick (01-10-2016), PaleMelanesian (08-08-2012)
