Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 04-19-2014, 01:09 PM   #121 (permalink)
Originally Posted by GTR View Post
Another note, is the Ferrari tire gas incident with McLaren in 07. McLaren stole Ferrari's super secret tire gas formula and according to Ferrari the gas made a huge difference in tire performance. The gas was basically half r404 refrigerant and half CO2 and I guess it helped transfer heat from/to the tire>air>wheel where the wheel performed somewhat as a radiator.
This I would try. Seems to have enough validity behind it to involve lawyers.
I have CO2 on tap from my welder and I am licensed to buy R-404a.
Like I said yesterday, it would be a lot cheaper than helium and leak out slower too.
Main intrest would be in filling trailer and truck tires, not so much little car tires, since I have had a heat related tire failure or 2 on the suburban.
Old 04-24-2014, 01:20 PM   #122 (permalink)
I did some searchig around. Found the stayfill site.
I believe they are selling over priced fluorocarbon.
But they claim CO2 leaks out at a nearly catastrophic rate. Which seems doubt full that it could be that much worse than air.
Guess some one should test it.
ok I will.
Old 04-24-2014, 01:43 PM   #123 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
ok I will.
I laughed....
you're talking to yourself.....
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-07-2014, 01:13 PM   #124 (permalink)
Lets see if this unicorn can give birth.
CO2 is on tap and I filled a tire with it a day or 2 after my last post and guess what, a radial tire holds it just fine.
Now for next phase. Through a series of horse trades I was able to get 7lb of R-404a.
Since I dont know if this will deliver any measureable results I didnt want to flush money down the toilet at the rate of $20lb, so I traded stuff I didnt have a use for to get it.
Look for it in general efficiency, you will know it when you see it.
Old 05-07-2014, 01:18 PM   #125 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I would like to find a way to fill a tire with a durable dense memory type of foam.
There must be a super foam of sorts that would work.
Save gas
Old 05-07-2014, 08:26 PM   #126 (permalink)
To Be Determined (Too-be) - '15 Chevrolet Malibu LS Eco
90 day: 35.41 mpg (US)
Long ago my dad found a bicycle inner tube that was filled with just that sort of thing. I freaking hated it. It was heavy and rode like poo.
Old 05-07-2014, 08:30 PM   #127 (permalink)
mcrews's Avatar
My buddy w a ranch has a foam in his tractor tires to avoid flats (not the green gu stuff)
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-07-2014, 08:42 PM   #128 (permalink)
Problem with the foam is I think it could build up too much heat in a highway driven tire.
It might work for a car.
I agree the foam is going to have a lot more mass than any gas.
Old 05-07-2014, 11:55 PM   #129 (permalink)
ecomodded's Avatar
It would need to be a very dense foam, equal to say 50 psi for me ( I like the rough ride)
The foam probably would get quite hot from the tire and retain it, I bet this avenue has been researched by the foam/chemical companies.
Name:	Airless wheel.jpg
The flexible air-less wheel they designed some years ago would be a better direction to follow and more suitable to the 21'st century then my foam fill idea..
My Stepfather uses a white powder(I think it's powdered lead) in his 4x4 lawn tractors wheels for traction.
What kind of foam is in your friends tractors tires ?
Save gas
Old 05-08-2014, 12:18 AM   #130 (permalink)
ecomodded's Avatar
QUOTE oil pan - I was able to get 7lb of R-404a -
You have a good amount !
Speaking of heat
Won't the heat generated by the tire raise the psi of the R404a quickly ?
Save gas
