Old 12-18-2008, 05:33 PM   #291 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
I just worked up the courage, so I'm going to get an arduino kit now and then when you create the schematic for CAN I will follow it religiously . Thank you so much.
Old 12-23-2008, 10:31 AM   #292 (permalink)
I have a quick question about the buttons. Does it matter if they are normally Open or normally Closed?
Also, I tried testing the new ISO code, and it didn't respond, but it might be my 33290 chip. I thought maybe you had it wired up wrong in your diagram, and switched the 5,6,7,8 pins around according to the picture on the spec sheets, But it caused a nice spark when i tried to plug in the obd connector. Turns out the picture on the data sheet is wrong, but the text and your diagram are right
Old 12-23-2008, 10:54 AM   #293 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Buttons are "Normally Open" I believe in the MPGuino version - when you push the button, it completes the circuit. Check the "release one workspace" thread post 1 - it shows the diagram of the buttons.
Old 12-23-2008, 12:47 PM   #294 (permalink)
Thanks, yup, they are normally open in all the pictures. I think I was just secretly hoping that they were interrupt driven that made it so it didn't matter.. for example triggered on a rising edge...
I guess I will have to pick some of the proper ones up
Old 12-23-2008, 08:45 PM   #295 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
For ISO, try to reach RussEnterprises, he told me he got the init done by modifying the code, ask him also how he wired his 33290
2013 Hyundai Sonata Hybrid
Old 12-23-2008, 11:32 PM   #296 (permalink)
Civic 4 Life
KJSatz's Avatar
Ooh cool I see you have the new CAN interface with the MCP2551 and MCP2515 instead of the ELM327 up on the wiki! So cool! Do you have this working in your car? Could I see a picture of your interface?
And if I may ask a dumb question, where does the +5V come from? Edit Let me see if I can answer my own question and you tell me if I did it right. +12v comes from the OBD-II port, through the interface ("daughterboard") where there's the on/off switch, then to the +9V power pin on the Arduino. Arduino electrical regulation magic gives us +5V out on the +5V pin, where the interface gets the +5V.
Old 12-30-2008, 07:48 PM   #297 (permalink)
OBDuino coder
Magister's Avatar
you're right and here's some pic
front:
back:
I tested the code on full tanks, I still need to introduce a new parameter to adjust the fuel consumption, then work on a schematic anc a PCB
Old 12-31-2008, 01:03 AM   #298 (permalink)
Civic 4 Life
KJSatz's Avatar
Such exciting progress! Thanks for all the work you're putting into this.
Man I'm such a lame cheerleader.
Would an iDuino work with this?
Old 02-01-2009, 03:19 PM   #299 (permalink)
I'm looking to find out if anyone has been able to get the ISO code working for obduino? RussEnterprises?
I have an ISO9141 vehicle, I built an interface using the MC33290, but I'm having trouble getting the communication initialized, it hangs on the iso_read_byte() from iso_init(). I have only tried v112, and it just displays the init screen. Any hints where to go from here?
Old 02-01-2009, 08:38 PM   #300 (permalink)
I just got it working with ISO9141 using the MC33290 yesterday. It isn't well tested, and I haven't had a chance to send the code to Magister to be integrated into the google code release yet, though. If you want to PM me with your email address, I can send you the ISO9141 only code that works for me.
Russ
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
