Old 08-10-2012, 04:14 PM   #801 (permalink)
OK I can't seem to get this damn thing working with ELM327 using ISO...... WTF???? Every single PID just acts as if the PID isnt supported!!!! After 3 years I would have figured someone got this thing working!!!!! ANYONE???
Old 08-10-2012, 04:21 PM   #802 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
For ISO version people used the standalone chip version. The ELM327 should work, problem may come from the line with ATSH6810F1, just remove these lines and try
else if(str[1]=='3') // ISO 9141
elm_command(str, PSTR("ATSH6810F1\r"));
2013 Hyundai Sonata Hybrid
Old 08-10-2012, 05:19 PM   #803 (permalink)
Ok.... Compiled it, and headed out to test here in a couple minutes!
Old 08-10-2012, 06:20 PM   #804 (permalink)
SCORE!!!!!!!!!!! Worked great!!!!! Thats awesome! One final question.... Is there a way to speed up the response time... like how fast the RPM's read???
Old 08-10-2012, 07:32 PM   #805 (permalink)
OBDuino coder
Magister's Avatar
ISO is a slow protocol at 10400 baud so the speed limitation comes from it...
Old 08-10-2012, 07:38 PM   #806 (permalink)
AHHHH Ok.... I think I can deal with it though! But isnt it actually set to 9600 Baud rate? either way though, Thank you So much man! U rock!
Old 08-11-2012, 08:40 PM   #807 (permalink)
If it were 9600, we could use any old serial port or USB to communicate with our cars. So, no, that couldn't be allowed.
Old 08-12-2012, 01:30 PM   #808 (permalink)
Nick, Baud rate is just how fast the information transfers. to communicate to the car you would still need a "Translator" wether its the ELM chip, STN chip, or one of the MC chips.
Old 08-22-2012, 03:51 PM   #809 (permalink)
hey fellas!
I am using ELM327 version.
Testing my obduino I noticed, that it cannot reinit after engine is been turned off...
Actually I dont understand how obduino senses when car is being turned on again.
maybe someone can explain that?
I have the #define SaveTripDataAfterEngineTurnOff part enabled. when I start my engine before obduino is connected to car, everything works fine. I turn off the engine, display says trips saved and backlight goes dim.
when I start the car I can get obduino to work again only by pressing reset or menu button.
another thing, when I turn on ignition and obduino inits before engine is actually started, backlight stays off and obduino wont work untill reset is pressed or menu button is pressed.
I was thinking, what about using one pin and reading ignition on it? like, when pin is high do elm init, when pin is low - save trips.
otherwise this tool is brilliant
any ideas?
thanks
Old 08-29-2012, 11:14 PM   #810 (permalink)
Does that happen to other OBDuino owners? Sounds like it gets hung up, because of lost communications with the car. (i only have MPGuino, but plan to add OBD code to it)
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
