Old 08-30-2012, 04:50 PM   #811 (permalink)
Yea.. Mine does the same thing... I created mine with a shut of switch, i just turn it off and back on again
Old 08-30-2012, 05:24 PM   #812 (permalink)
Here's a question. I want to change the MAP reading display from KPA to inches of murcery in vacuum, and PSI in boost. Anyway to amke this happen?
Old 09-03-2012, 07:45 PM   #813 (permalink)
Wow!! This would blow my MPGuino out of the water! I had no choice when searching for a MPG and trip computing system. Would it be at all possible to use this with a 1989-90 vintage OBD1 (Chrysler Style) engine? I do have a supplemental Over/Under drive I can get pulses per mile from....It's only TBI, so injector Pulse Width isn't all that great as a measurement.
What do you all think? Is this doable???
Rich "The Wanderman"
Old 09-03-2012, 11:56 PM   #814 (permalink)
i'm pretty sure this one is only for OBD2. sorry
Old 09-17-2012, 08:29 PM   #815 (permalink)
Hello , i have a question in regards to JOBD , my Mitsubishi Galant '99 made in Japan , seems to be equipped with JOBD , that pretty much means that ELM will not work for me. As far as i see JOBD is included in the OBDuino code (at least i see it, searching for "jobd") ,so in theory it should work if the signals from the 16 pin connector are driven in to the Arduino ... how do i do that ? Is there an other suitable chip ?
Any help would be appreciated , thanks.
Old 09-18-2012, 02:28 AM   #816 (permalink)
it is not the type of plug that counts, it's the protocol...
try to find out what protocol is your jobd running.
Old 09-18-2012, 09:37 AM   #817 (permalink)
The exact protocol is MUT-II ,seems to be pretty common fot Mitsubishi even the Evo-s (up to 8) have it.
Old 09-18-2012, 01:50 PM   #818 (permalink)
I have no idea what connector you got there, but after little googling around I understood that MUT is Mitsubishi specific diagnostic tool or protocol or something... as far as I know OBDuino doesnt need vehicle specific protocol, but general - iso, can etc...
jobd is japaneese standart for obdII. shouldnt the plug be the same as normal obdII?
Old 09-18-2012, 07:32 PM   #819 (permalink)
The connector is the 16 pin OBD II-like one ,the data is оn the K line: Mut II , 15625 baud rate. I will try to get the exact protocol, probably not much different than OBD2 .
Old 06-24-2013, 04:07 PM   #820 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Anyone know where migght be the problem?
I have version 198.
When i upload the ELM code, it's just stuck on the screen "OBDuino32k v198"
I tried those things people said few comments ago, but no effect.
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
