10-16-2012, 08:57 PM
#11 (permalink)
Aero Wannabe
Ingenius! Simple materials, novel application.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
10-17-2012, 03:33 AM
#12 (permalink)
Looks cool! Good job!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
10-17-2012, 02:24 PM
#13 (permalink)
For some reason I can't understand, I had never seen this thread. Nice job! Your top hinged skirt design will be very practical when changing tires.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
The Following User Says Thank You to HyperMileQC For This Useful Post:
10-17-2012, 03:09 PM
#14 (permalink)
What's the white perforated material ?
10-17-2012, 06:05 PM
#15 (permalink)
T-100 Road Warrior
It's a plastic corner bead fer archways. It's cut on the one side so you can shape it. It costs about $3 at Home Depot fer a 10' long section. You should be able to find it along side with the other drywall corner bead stuff.
Dark Aero-The world's first aerodynamic single wheel boat tail!
10-17-2012, 06:06 PM
#16 (permalink)
T-100 Road Warrior
10-17-2012, 06:55 PM
#17 (permalink)
partial
Originally Posted by BamZipPow
I've nothing specific on partials,but the scary voice in my head says that a wind tunnel would show a benefit.
The air can't just tumble in immediately,and since it's longitudinal flow is maintained longer along a solid surface,when it does run out of skirt,and stumble into the void,the void is smaller,and so the perturbation should be smaller as well,with easier downstream recovery when it see's the surface rear of the tire.
10-17-2012, 07:00 PM
#18 (permalink)
view
Front view...before the rain hit.
Yum yum! Oil will probably dropped $5.00 a barrel as soon as you hit the public roads!
10-17-2012, 07:53 PM
#19 (permalink)
T-100 Road Warrior
Just so everyone knows...when I did my partial wheel skirts along with my other mods...I got my best MPG last year at almost 35mpg at 65mph. My best before that was 28mpg. My truck is rated at 19mpg.
Right side buttoned up...
Front view...
Rear view...
Left side rear view...
I'll eventually trim it down to the outline of the wheel well and fab up a separate brackets fer the front and back sides. To lift it fer access to the tire will require the removal of 2 screws and 2 bolts.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
11-21-2012, 10:56 PM
#20 (permalink)
T-100 Road Warrior
Had a chance to build the front support fer the rear wheel skirts...
Used some PVC pipe and a 12" metal Simpson Strong-tie strap.
Looking to git a few aluminum yardsticks to use as the shaped support fer the rear wheel skirts so I can lose the wire and add extra support across the skirts. Should be cheap enough and easy to shape.
Here's the right rear wheel skirt...it was rubbing in a few places.
The Following User Says Thank You to BamZipPow For This Useful Post:
