06-05-2009, 10:27 AM
#1561 (permalink)
I was just glancing over the schematic and noticed that pins 4 & 5 of J1 have the same net name, my PCB cad package would tie them together. Hope that is not an issue with yours.
06-05-2009, 11:03 AM
#1562 (permalink)
Originally Posted by MazdaMatt
quick googling turned up nothing... are the atmel users just not interested in interrupt driven communication? Every uart code snippet I saw had a while(blah blah){sit here with your thumb up your...}
Code:
FUNCTION Main
Enable Global Interrupts
LOOP FOREVER
{Do Stuff}
Transmit_Data(Data)
Sleep
END LOOP
END FUNCTION
FUNCTION Transmit_Data(Data)
Store Data into RingBuffer
Enable TX Buffer Empty Interrupt (instead of Dean's TX Complete Interrupt)
END FUNCTION
ISR TX_BUFFER_EMPTY_ISR
IF RingBuffer NOT EMPTY
UDR = RingBuffer.Next
ELSE
Disable TX Buffer Empty Interrupt
END IF
END ISR
More about that, including a link to a ringbuffer implementation fond in the same place as the (pseudo)code above: View topic - [TUT] [SOFT] Using the USART - Interrupt driven serial comms :: AVR Freaks
06-05-2009, 01:28 PM
#1563 (permalink)
Thanks, Charlie. It is pretty easy when you aren't going to be receiving and you aren't using any kind of proper data encapsulation.
06-05-2009, 06:51 PM
#1564 (permalink)
PaulH
An update from our friendly neighborhood engineer...
Installed all connectors and the input components only (see pic). Here is where I start to test:
-Reverse polarity protection
-Overvoltage clamping @19V
-Common mode filtering of noisy +12V input (I'll attach a +12V brushed motor in parallel with input to verify spikes don't get through)
06-05-2009, 07:07 PM
#1565 (permalink)
EcoModder Student
Beauty....beauty.....beauty!!
A long way from a radio skank bread board.
Thanks for the progress report. It does a body good.
Eric
1995 BMW 318i EV in the making
06-05-2009, 07:28 PM
#1566 (permalink)
For a "cheap motor controller" Its looking great.
Just curious, but what is the minimum voltage this controller would be able to run / control a car at?
06-05-2009, 07:49 PM
#1567 (permalink)
PaulH
The minimum voltage that you can give the controller for driving the car is 0, and the maximum is about 150v. At 0 volts, your top speed will be pretty low. hehe. But the controller would be perfectly happy with, say, a AA 1.5v battery as the power source for the motor. That's the beauty of powering the controller with the 12v auxiliary battery (but using an isolated DC-DC converter inside the controller). Absolute flexibility with the pack voltage! ya! And if someone uses 600v IGBTs, diodes and caps? Then the allowable battery pack voltage would be 0 to about 550v or so. Otmar, the Zilla maker, suggested to me that isolated DC-DC that we're using.
06-05-2009, 09:56 PM
#1568 (permalink)
PaulH
As for cheap motor controller Oh, ya... I believe in bulk, that those control boards would cost around $8 each! ya! 2 Radio Skank boards (hehe, that was really funny Eric) cost $8!
I just bought the aluminum plate for the base of the controllers. It will be shipped here in a few days, then I'll drill the appropriate holes in it. The plate is 3/8"x7.875"x38.375", so I can hack that up to whatever it needs to be. That will be a nice solid base, and a pretty dang good heatsink too. So, Hondo, could you make those enclosures so that the fins stick out so that the total width of the enclosure is around 7.875" wide or so? hehe. I only need to really settle on the internal height and length now. It will be around 3.5" high or so inside I'm thinking, and maybe 10.5" long ERRRRRRR SOooooo! I really need to figure that out! I wasn't sure how tall the control board would end up being, but now I have an idea of that. I am so sorry that I've slacked in that department! I'm such a internal dimensions slacker!
06-05-2009, 10:28 PM
#1569 (permalink)
For the power stage, what about oil cool it? Put it in a sealed container, seal up the power and control lines, connect a cooling system with a pump and transmission cooler, and fill it with transformer oil. Something like one of those speciality PC power supplies. JonnyGURU.com - Power Supply Reviews and more! - Reviews - Koolance PSU-1200ATX-12S Liquid Cooled 1200W power supply
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
06-06-2009, 12:17 AM
#1570 (permalink)
MAD Modder
Reason: Clarification
