Old 03-18-2010, 03:07 PM   #3221 (permalink)
EVVette - '71 Chevy Corvette Coupe
Originally Posted by Flatmann100 View Post
I'll go back through the laptop and see where Its set right now. Da I should have tried that
right click on my computer>properties>hardware>device manager, and look at ports. it will tell you what com port your serial port is.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 03-18-2010, 03:28 PM   #3222 (permalink)
E-car - '84 Toyota Corolla LE
Hmmm
Old 03-18-2010, 03:56 PM   #3223 (permalink)
Adam
All my ports are RIM virtual ports, USB. The choices I get from Realterm match the ports my laptop has 13,14,15,16,& 17. Only com 3 works in that CTS and DSR go green.
Old 03-18-2010, 04:01 PM   #3224 (permalink)
Adam
What is the serial adaptor that you are using??
I think that might be the problem.
-Adam
Old 03-18-2010, 04:14 PM   #3225 (permalink)
I did a search of "serial adaptor" in my computer and it returns with "no matches" found. I'm running "Vista"
Old 03-18-2010, 05:31 PM   #3226 (permalink)
omy. just finished reading all 3200 posts! do i get a prize for actually reading all those?
good job guys!
i am in the research phase of a first time ev conversion. looks like your latest 1000a controller will be my choice.(chin up Paul, you will get it)
is there a reason fran does not post? sounds like he puts in huge amounts of effort just like paul and the rest. GJ Fran!
Old 03-18-2010, 05:53 PM   #3227 (permalink)
Flatman, right click "my computer"
choose properties.
go to the "hardware" tab
click "device manager"
look for "ports, com & lpt"
click the + next to them.
it will show you what com ports you have installed.
i believe that will work for vista.
edit: or just search for "device manager"
Old 03-18-2010, 08:56 PM   #3228 (permalink)
Hi Caspar, Looking in the device area I have ports 13 through 20 loaded. I have been trying to create a com 1 without success. I think I'll find an older computer, maybe an old desk top to get over this obstacle. I'm at work now which will give me a chance to colaberate with others about this.
Thanks for the input.
Old 03-18-2010, 09:06 PM   #3229 (permalink)
Caspar, thanks for the input I dug deeper and found the tab I was looking for. I now have a Com1. I just wish I was at home to go try it out!!! Maybe I could call my boss and tell I'm feeling sick...... man am I tempted. hehe
The Following User Says Thank You to Flatmann100 For This Useful Post:
MPaulHolmes (03-18-2010)
Old 03-18-2010, 09:59 PM   #3230 (permalink)
Question on the Caps - is there any reason that we're using 16x 820uF instead of less higher capacity ones?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
