Old 02-29-2012, 07:31 AM   #5521 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
New power PCB design has tinned contacts for B+, B- and M- copper bus bars. Do I need to heat and tin my copper bars before attaching them to the PCB or would I be fine without soldering? I was going to use some conductive glue and simply clamp them together like I did on earlier design.
Old 02-29-2012, 03:33 PM   #5522 (permalink)
PaulH
MPaulHolmes's Avatar
You don't need to solder them to the power board. Just use the conductive epoxy again. At least that's what I've done and it seems to work fine.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
mora (02-29-2012)
Old 02-29-2012, 04:21 PM   #5523 (permalink)
Thanks for the info. It took few weeks to get proper flat copper sourced so I can start my controller rebuild now. Hope to finish it soon.
Old 02-29-2012, 04:32 PM   #5524 (permalink)
A couple weeks? Onlinemetals.com has really good stock on copper, and they are reasonable prices. Plus they also offer cutting (for like a dollar per piece) and they have pre cut pieces (random length between 10 and 12 inches) that seem to always be around 11.5 inches. And they have 110 alloy, which is about the best alloy u can get aside from 111
Old 02-29-2012, 04:50 PM   #5525 (permalink)
Yea, I took a look at their store before but didn't find any info about international shipping fees. Maybe I should have asked them. I got some copper bar from local scrapyard for my previous controller. It was cheap, hehe. I asked some companies if they had flat copper and best offer I got was 4m long bar. Oh, and most of companies I asked didn't sell to individuals. After all the searching I asked the same machinist who made my motor shaft coupler. He had some thick pieces of copper and cut them to bars per my needs. Aluminium is no problem to find.
Old 02-29-2012, 06:20 PM   #5526 (permalink)
oh! i had forgotten about international shipping. online metals only ships ups, but i believe ups has international shipping options. if you can find it locally though, that's perfect
Old 03-06-2012, 02:16 PM   #5527 (permalink)
Success. Controller works fine after repair. I replaced all the mosfets, whole power board and two diodes. Now voltage goes to 144V during precharge and even voltage sag seems to have lowered.
Question: for how long should caps remain charged? My previous controller lost cap charge in few seconds after opening the main contactor. Rebuilt controller holds charge for minutes and voltage decreases very slowly. Could that quick voltage drop have hinted me of developing short?
Old 03-06-2012, 04:59 PM   #5528 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
I think you answered your own question.
You should install a discharge resistor between pre-charge cap. (+) and (-) 12Kohms x 10 Watts to avoid those sudden electrical discharges.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 03-09-2012, 12:03 AM   #5529 (permalink)
PaulH
I used my math 102 class today to do a series of voltage, current and rpm measurements on a DC motor. the results:
if voltage is fixed, the amp-rpm curve is linear. for different voltages, the amp-rpm curves are parallel. So, you just need 2 of 3 volts, amps, and rpm to know the other one.
kits and boards
Old 03-10-2012, 01:37 PM   #5530 (permalink)
tazziboy7's Avatar
Drunken Sam - '88 Suzuki Samurai JX
White - '06 Hyosung 650GT
Subscribe
The Following User Says Thank You to tazziboy7 For This Useful Post:
MPaulHolmes (03-10-2012)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
