Old 12-10-2020, 11:06 PM   #11 (permalink)
Perry - '98 Honda Civic EX
90 day: 40.45 mpg (US)
Originally Posted by JulianEdgar View Post
Since you're in the aerodynamics section of the forum, I'd suggest as large an undertray as you can fit to the car.
Shoot, I meant for this to be a more general thread, and as such under Ecomodding Central. My mistake, but anyway the undertray suggestion is well appreciated. Im unsure with how to design a tray that would -under the engine- be *relatively* easy to take off without a lot of skill in bracketing and body. Would either of your books provide information on such things?
Im aware that im probably asking a lot: ease of design, ease of build, low budget, easy maintenance, durability. So if I'm in over my head i get it. Though I am considering aerodynamic mod's and testing, I again meant to have this thread under ecomodding central.
Old 12-10-2020, 11:37 PM   #12 (permalink)
What do you plan for supplementing/augmenting battery charging?
Credits to Daox https://ecomodder.com/forum/member-daox.html
Daox had the idea to: use a "smallish" ~15 V lithium pack and connect it to the starter battery (either directly or using the cars 12v plug). While maintaining enough voltage, the pack should be able to keep system voltage above that "set by the alternator, thus disabling it." Link below:
https://ecomodder.com/forum/showthre...ete-37923.html
I forget where I remember reading this, but I believe reading that Hondas 5th -or 6th?- VX or HX charging setup operated similarly, but without the extra battery supplement. It's alternator would charge the system when voltage dips below a low threshold and switch off after reaching a high threshold. I don't know how correctly I'm vaguely describing this, but I intend to learn of this systems mechanics and efficacy. If I can have/do this for my application, then this instead.
The Following User Says Thank You to dayvon For This Useful Post:
aerohead (12-11-2020)
Old 12-10-2020, 11:54 PM   #13 (permalink)
I haven't read the books but I expect they would be more about how to shape the tray.
I would consider a tab -and-slot arrangement with the tabs facing forward (to resist impacts) so any fasteners would only have to keep it from shifting forward.
...replacing the stock shocks and springs with lighter and adjustable coil-overs, swapping for alloy wheels, and using lighter cv shafts.
...will not have as much effect as the tire choice.
Old 12-11-2020, 12:31 AM   #14 (permalink)
Luddite
deluxx's Avatar
ol-green - '96 Honda Civic LX
90 day: 50.11 mpg (US)
Yes ! I use this, It helps!! https://www.autozone.com/test-scan-a...ck/1042041_0_0
Old 12-11-2020, 01:43 AM   #15 (permalink)
Old 12-11-2020, 02:11 AM   #16 (permalink)
So my prediction failed.
The product JulianEdgar proposes for the composite material DiBond, corresponds to other brands like Polymetal, Grimco Maxmetal and Alumapanel.
Old 12-11-2020, 11:17 AM   #17 (permalink)
alternator
If I remember correctly, even before the VX, Honda would reduce field strength to the alternator, allowing only 12-VDC while under low manifold pressure; as this condition would signify an acceleration, passing, or hill climbing event, where access to all available power was desirable ( without dimming the headlights, etc.).
Old 12-11-2020, 12:03 PM   #18 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The first time I took a rocker panel off my Viper I was very surprised to see that it was secured on the underside (which extends ~6" toward the center of the car) with sheet metal screws. A visit to one of the forums at the time confirmed that this was factory, and apparently they had a reputation for falling out and flatting the (very expensive) rear tires. Definitely an attachment method to stay away from.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 12-11-2020, 06:57 PM   #19 (permalink)
Interesting! And for people outside the US, sheet metal screws = self-tappers.
