Old 11-15-2012, 10:11 PM   #31 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
Resting my brain on it now
Grommets came in the mail, so I have material and I think a reasonable plan. Time to step back from this for about a week, traveling to Indianapolis on Sunday for work. Maybe Black Friday I pull off a wheel and take some pics as I give it a go.
Old 11-15-2012, 10:20 PM   #32 (permalink)
Does your Malibu have a factory FE gauge for some ABA testing?
Old 11-15-2012, 10:50 PM   #33 (permalink)
Team Chevy
Only average, not instant.
Just an overly optimistic avg, need to get an sg or ug for sure. I think it would be interesting to do. I found OEM one is about 10% high. My fuel log is reflecting a more accurate truth now that I am ignoring it. I do reset it on the fly for fun. Seems like mid to high 30's when I am doing 65 to 70? I heard TC lockup and 4th gear are good on my car, v6 spins around 2000 rpm at those speeda.
But I will not believe that my fe is that good at those speeds so I want an SG for help me.
Old 11-15-2012, 11:00 PM   #34 (permalink)
My Impala has same size engine, it's gauge is pretty accurate, I've had some 35 mpg 60 mile trips (holding it to 55 mph). Doesn't really matter if guage is accurate or not, if it give consistant numbers it will allow you to calculate percent change. I don't know the RPM off hand but would speculate it's the same gearing as yours.
Cold weather is pull both of our number down, last 3 tanks on the Cobalt all under 40 mpg.
The Following User Says Thank You to roosterk0031 For This Useful Post:
WesternStarSCR (11-16-2012)
Old 11-16-2012, 07:56 AM   #35 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Send pics
I found no issues with corrosion with alum wheels and ss bolts. Just take them out every month to check tire pressure and you are fine.
If you want to see how they are look like first/ want help with yours I am not that far away (midland) if you want to meet.
The Following User Says Thank You to Weather Spotter For This Useful Post:
Old 11-16-2012, 10:52 AM   #36 (permalink)
Team Chevy
thanks again
Originally Posted by Weather Spotter View Post
Send pics
I am going to add pics to first post as I start the dirty work next week, Friday hopefully. My dad happens to have a tapping handle, so once I borrow that I should be good.
Very kind of you to offer your time WS. I will have to take it up hopefully at some sort of Michigan meetup with whoever else would be interested, maybe in the Spring? Good brewery in Frankenmeuth...
I am using grommets to keep my air valves accesible, but I will be able to inspect the back studs every tire rotation.
I picked up a 100 pack of the nylon lock nuts, so I can replace them from time to time since the nylon only works a few times from what I read soemwhere.
Old 11-16-2012, 11:43 AM   #37 (permalink)
Wiki Mod
Little Bavaria is a nice tourist trap town. But it is in a good spot for a meet. Do we want to plan on for spring time ?
Old 11-16-2012, 01:19 PM   #38 (permalink)
Team Chevy
OK, a meet up it is...
http://ecomodder.com/forum/showthrea...tml#post340302
Old 12-03-2012, 11:24 PM   #39 (permalink)
Team Chevy
Test fit pictures and collection of supplies
Added a dozen pictures to my Album:
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - WesternStarSCR's Album: Smooth Wheel Covers
Test fit success:
My Helper:
Grommets:
Edge View:
I want to get this done now that I saw what it is going to look like.
Old 05-07-2013, 10:06 PM   #40 (permalink)
90 day: 51.82 mpg (US)
Any news/update on the wheel covers? All four made it on the car?
aluminum, chevy, malibu, pizza, wheel cover
