Old 06-03-2009, 08:22 AM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Also, don't hit me for saying this, but you should only get a speed/mpg reading if the car is moving.
Old 06-03-2009, 09:07 AM   #12 (permalink)
I was using a t now i am directly connected to the vss. or what claims tobe the vss per my owners manual. I get a c reading now and have corrected the engine wires from faulty cut out. where can i troubleshoot this thing next. I do get continuity to the vss from the mpguino.
Thanks,
Jim
Old 06-03-2009, 09:21 AM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
You have tried driving around a bit then?
Old 06-03-2009, 09:42 AM   #14 (permalink)
yes I have driven around a bit. I have taken it for 2 test runs 5 miles each. I do not have a speedometer reading and all of the mpg readings are showing zeros. Is there any settings on the setup I should compare?
Thanks
Old 06-03-2009, 09:45 AM   #15 (permalink)
also I still have a check engine light showing ,if that is an indicater of any mishaps.
Old 06-03-2009, 10:15 AM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
Well fuel is the critical one, so that is good progress. Can you figure out what code is set with that light, and what the computer is trying to tell you?
Old 06-03-2009, 10:24 AM   #17 (permalink)
I don't have anything to read the codes on my computer. This MPGuiNO gauge is the 1st and only read I have for the car.
Old 06-03-2009, 10:30 AM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
google for 1993 metro code , you will probably have to jumper something and watch the blinky check engine light or something. Teamswift.net probably has something on it too. Could be the injector circuit wasn't happy or something is up with the vss circuit wiring now. dunno, ask your cars computer
Old 06-03-2009, 10:44 AM   #19 (permalink)
any ideas why MPguino is still not reading the vss?
Old 06-03-2009, 10:50 AM   #20 (permalink)
somebody else had an issue with a vss in a metro on this forum and said something about needing voltage applied to the vss on a 93 metro to get a read. I just don't understand what needs to be done. Or how to do it. I am all new to this.
Restoring a 1989 Geo Metro IheartGeos Introductions 18 02-22-2010 01:00 AM
93 Geo Metro timing belt check? ncsteve EcoModding Central 0 05-09-2009 10:52 AM
My 1989 Geo Metro Story owlafaye Introductions 2 10-05-2008 06:31 PM
'93 Geo Metro EOC question Newton Hypermiling / EcoDriver's Ed 9 09-19-2008 03:11 PM
Geo metro 93 vss and injector leads GeoGreg OpenGauge / MPGuino FE computer 4 09-13-2008 06:45 PM
